All thats required is long reach road brakes. Most LR work for reaches from 41mm to 56mm from the center of the brake bolt to the center of the braking surface. I have even had 700 forks made up for some but it's a little costly. Venturing into old steel is FUN but can be challenging, not for every body. I do steer clear of odd weak seat posts clamps and Italian bottom bracket stuff, but thats just me. This 62cm LeMond Zurich in Reynolds 853 high strength, 210,00 psi, heat treated, air hardened steel alloy in 700 wheels . ...
. Another good bike to look for.
