Bike and Cycling Forum > Bike Rack > Mechanic's Bench > Handlebars Keep Moving
Old 11-07-2012, 02:09 AM   #1
Residential Noob!
rynoman03's Avatar
Liked 461 Times on 325 Posts
Likes Given: 1179
Got this cheap bike from a friend for $50.00 just to get out and exercise and for another type of exercise. I've got things tightened up and got things mostly set where i want. My main issue is the handlebars keep moving on me. It seems the splines are kind of stripped \ have a flat spot. I have moved it and adj things then tightened the living crap out of the clamp on the stem too.
If it continues to move can a guy put athletic tape or anything around the bars to get them to stay tight? They aren't moving nearly as bad as they were but today they broke loose a few inches when bouncing off some roots and rocks.
Any help would be greatly appreciated.
rynoman03 is online now
Old 11-07-2012, 02:29 AM   #2
still learning
superj's Avatar
Liked 633 Times on 454 Posts
Likes Given: 12
find a thin thin piece of aluminum and put in there. my aerobars came with some thin aluminum spacers for different sized bars
you should try this link:
https://www.biketexas.org/
superj is online now
Old 11-07-2012, 02:59 AM   #3
Liked 1990 Times on 1313 Posts
Likes Given: 2207
I don't normally suggest anyone drink a beer from a can, but that's the best source for some thin shims. The problem is that someone moved the bars before they were fully loosened, and now they are stripped.
Note: Depending on the severity of the damage, you could be putting yourself at risk for injury.
Old 11-07-2012, 02:59 AM   #4
Residential Noob!
rynoman03's Avatar
Likes Given: 1179
You think aluminum flashing for roofing would do the trick? I think i have half a roll left from re-roofing my house.
Old 11-07-2012, 03:01 AM   #5
Likes Given: 2207
Beer would be more fun.
That aluminum tape for your HVAC vents would work well too.
Old 11-07-2012, 03:04 AM   #6
davereo's Avatar
Liked 1249 Times on 761 Posts
Likes Given: 1496
I have loads of shim stock. Stop by if you need some.
John Heisman
davereo is online now
Industry_Hack Likes This
Old 11-07-2012, 03:05 AM   #7
Residential Noob!
rynoman03's Avatar
Likes Given: 1179
I think i have a few Coors Light's that need drinking in my fridge. I guess I could give it a whirl. Then it would have the "Silver Bullet MOD"
Old 11-07-2012, 03:08 AM   #8
davereo's Avatar
Likes Given: 1496
Make sure you trim the can shims narrower than your bar clamp. Having the shim sticking out will be like a razor blade.
John Heisman
Old 11-07-2012, 03:14 AM   #9
Residential Noob!
rynoman03's Avatar
Likes Given: 1179
Good Point.
Old 11-07-2012, 03:17 AM   #10
Liked 316 Times on 220 Posts
Likes Given: 72
Scotty
Bartlesville, OK
StormStrikes is online now
Handlebars pottsman21 Road Bikes 2 08-07-2012 11:20 PM
Handlebars cvgreg Beginners Forum 10 05-17-2010 08:00 PM
Bike manufacturing moving back to the USA? Grape Ape Industry News 2 08-22-2009 03:49 PM
