Bike and Cycling Forum > Bike Rack > Mechanic's Bench > Rear derailer problem?
Old 11-05-2012, 02:03 AM   #1
evade65's Avatar
Hi all ,
I'm new to this forum and it looks great, however I am new to biking and was wondering if somebody could give me some advice? My bike is going up and down gears more or less ok, however when I stop peddling it swings?
evade65 is offline
Old 11-05-2012, 04:52 AM   #2
Merlincustom's Avatar
Liked 338 Times on 202 Posts
Likes Given: 142
I don't think it's the derailleur. Looks like the pawls inside the freebub body aren't disengaging when you stop pedaling. Could be a broken spring inside the body.
Merlincustom is offline
rola643 Likes This
Old 11-05-2012, 05:52 AM   #3
evade65's Avatar
Somebody else advised that too, that also said it may just need lubricating ? It may not be broken as it a brand new bike
evade65 is offline
Old 11-05-2012, 11:02 AM   #4
Likes Given: 142
If it's a brand new bike it may need less lubricating. If the pawls were overgreased, the excess may be impeding their ability to retract when you stop pedaling. The bearings do need grease; too much and it seeps over to the freehub body and mucks up the pawls. The pawls/freehub body just need oil. I'd take it apart, clean it, be a little sparing in the use of grease for the bearings on the drivetrain side, and use a little oil around the pawls, not grease (or have the shop do it for you).
Industry_Hack Likes This
Old 11-06-2012, 04:01 AM   #5
Leave Lance alone...
DirtyBobbysBikes's Avatar
Liked 34 Times on 25 Posts
Likes Given: 25
Lose the Frisbee. I see those things jam up and do that all the time.
DirtyBobbysBikes is offline
Old 11-06-2012, 09:03 AM   #6
Likes Given: 142
That would be a much easier fix! Plus, it's Occam's Razor. Hope it's that for the OP's sake.
Old 11-06-2012, 04:07 PM   #7
evade65's Avatar
Lose the plastic guard you mean? I could try that yes, I have been using the bike the last few days and it still does it, is there any chance no matter how small the if the gears are not set right it could cause this? As I don't think they are quite right because when I change Down it does not go to the lowest sprocket , thank you all for your advice too, I'm very new to biking
evade65 is offline
Old 11-06-2012, 05:07 PM   #8
Likes Given: 142
1. Yes, lose the guard.
2. No, derailleur adjustment is not causing your original problem.
3. Your new problem could be a limit screw issue.
Did you buy this brand new bike from a shop? They need to make it right free of charge.
PS. Rethink on 2 above, is your upper derailleur pulley contacting the cassette at any time? Couldn't tell from the vid.
Old 11-06-2012, 08:05 PM   #9
Makoguy's Avatar
Liked 21 Times on 12 Posts
Likes Given: 9
I agree, too much sticky grease in the rear hub or the pulley is set to close to the cassette. You should be able to identify the problem just by listening to the different sounds coming from the rear hub area. Good Luck.
Makoguy is offline
Rear derailer?? bikerman66 Mechanic's Bench 8 10-03-2012 01:01 AM
What's your problem? rola643 Activism / Safety 2 04-21-2011 10:33 AM
Replace shifter or derailer? Alexia General Bike Discussion 4 07-21-2009 09:09 PM
Looking for a new rear derailer Roadhero General Bike Discussion 2 06-08-2009 07:03 PM
