Bike and Cycling Forum > Bike Rack > Mechanic's Bench > Shifting issues
Old 12-03-2012, 11:46 AM   #1
The Back Row
synack's Avatar
Liked 689 Times on 481 Posts
Likes Given: 1132
Shifting issues
My bike is fairly new and it is probably due for a break in tuneup, but the LBS is pretty far and I think I should learn how to do most of this myself. I am fairly good at mechanics so I am not afraid to tackle this.
Cassette 12-25t
105 shifters (hidden wire model)
There is a delay when shifting into the 13 or 12 tooth gears. This happens either way I shift, up or down, the rest of the gears are fine.
This could be as simple as a clean and and oil but I suspect it may need a turn of the barrel adjusters? I would monkey around with it and figure it out myself but it's probably good to post up these problems for others to learn from.
Thanks!
Bianchi Sempre 105
synack is offline
Old 12-03-2012, 12:25 PM   #2
Liked 1990 Times on 1313 Posts
Likes Given: 2207
Which chainring are you on when it does this?
Industry_Hack is online now
Old 12-03-2012, 12:28 PM   #3
The Back Row
synack's Avatar
Likes Given: 1132
I'm a stud, the big un'!
Bianchi Sempre 105
synack is offline
kneedrachen Likes This
Old 12-03-2012, 12:33 PM   #4
Likes Given: 2207
Your rear derailleur should want to drop the chain to the small cogs automatically. Tightening the cable won't improve that. Loosening it might.Has someone been messing with the cables?
Old 12-03-2012, 12:35 PM   #5
The Back Row
synack's Avatar
Likes Given: 1132
No, it's been shifting great until recently. (Unless my two year old decided to play with the barrel adjusters?)
I haven't cleaned and lubed it since I bought it about 500 miles ago.
Bianchi Sempre 105
synack is offline
Old 12-04-2012, 01:19 AM   #6
Merlincustom's Avatar
Liked 339 Times on 203 Posts
Likes Given: 142
Exclamation
Cassette 12-25t
Thanks!
Interesting. The delay going into the 12 is possibly an outermost cog limit screw issue, especially when you say the delay is in both directions. If the delay were in only one direction, from the next biggest cog to the 13 and from the 13 to the 12, I'd say that was a barrel adjustment issue and would tweak it a quarter
turn clockwise to see if it makes the shift without delay. But if it's hesitating from the 12 to the 13 and from the 13 to the next largest cog, well, you can't turn the barrel adjuster a quarter turn in both directions, now can you? And what are the odds of it being 2 problems, limit screw and index adjustment, at the same time? Occam's Razor counsels against that. Hesitation from the 12 to the 13 and from the 13 to the next largest cog calls for a counterclockwise quarter turn to see if it makes it.
I'd eyeball the cage below the 12 to see if it looks like the limit screw is okay (that part of the chain closest to the 13 isn't touching the 13). Then I'd tweak the barrel a little going from low to high and high to low and see what happens.
Merlincustom is online now
Old 12-04-2012, 03:04 AM   #7
Liked 335 Times on 257 Posts
Likes Given: 2
You guys that can figure out this mechanical stuff amaze me - you lost me at limit screw and index adjustment - Occam's Razor I get but that is about it - Merlin you rock !
bikertank is online now
Industry_Hack Likes This
Old 12-04-2012, 11:39 AM   #8
Likes Given: 142
It ain't me, just a well worn, grease stained copy of this guy: http://www.amazon.com/Barnetts-Manual-Analysis-Procedures-Mechanics/dp/1931382298
Old 12-04-2012, 12:36 PM   #9
The Back Row
synack's Avatar
Likes Given: 1132
Thank you for all of the advice on getting this resolved. I will check the bike over again this evening. The one thing I remember doing is taking the rear wheel off, maybe I did not put it back on centered or possibly didn't put enough tension on the quick release?
I just think it's odd that the shifting has been perfect for so long and now is acting up.
Bianchi Sempre 105
synack is offline
Old 12-12-2012, 06:43 PM   #10
kneedrachen's Avatar
Liked 2187 Times on 1337 Posts
Likes Given: 4692
any resolution?
A true warrior feels fear but says **** it
kneedrachen is online now
STRAVA issues rola643 General Bike Discussion 6 10-25-2012 07:17 PM
Saddle/Seat Issues LiveFreeRideHard General Bike Discussion 16 08-02-2012 06:58 PM
Issues with pedals (look keo blade) ballyheefy Road Bikes 0 02-26-2012 07:20 AM
Electronic shifting? bikebum1975 General Bike Discussion 16 09-21-2011 04:37 AM
Drivetrain Issues... Last_Place_Pete General Bike Discussion 5 05-01-2011 11:03 PM
