Bike and Cycling Forum > Bike Rack > General Bike Discussion > 1st build
Old 09-16-2011, 04:01 AM   #1
1st build
I am working on turning a full susp. bike into a single speed. Is it possible to use a bmx bike for parts. (chainset, rear cassette)?
Thanks
Joe
IHATEICECREAM is offline
Old 11-29-2011, 06:35 AM   #2
punisher59's Avatar
To me it seems the give in the rear suspension triangle would cause slack in the chain leading to it jumping off at every bump in the road. Just saying?
punisher59 is offline
Old 11-29-2011, 04:00 PM   #3
Official thread destroyer
DirtyBobbysBikes's Avatar
Although it can be done it would not be as simple as converting a hardtail bike. I guess it really kind of depends on the suspension design too.
DirtyBobbysBikes is offline
Old 11-30-2011, 07:31 AM   #4
punisher59's Avatar
What if you left the rear derailer on it and used the tension spring in it to compensate for the chain slack created by the spring/shock compressing on hits? Lock it down some way to align with the rear sprocket.
Old 11-30-2011, 11:30 PM   #5
You'd almost have to have a tensioner of some kind. a derailleur would work. If you can't set the limit tight enough to put the chain were you want it then use an old shift cable. Run the end through the barrel adjuster on the derailleur and try to set it as close as possible. then you can tune it out with the barrel adjuster. Any pics of what this is going to be done with?
Power Tool Build sausagetree Motorized / Electric 10 03-26-2012 04:25 AM
Hybrid build mysticalman Hybrid 9 05-22-2011 01:23 PM
Lowrider Build TxCyclist General Bike Discussion 5 07-20-2009 11:53 PM
