Bike and Cycling Forum > Bike Rack > General Bike Discussion > 2 bolt stem and BLUE loctight
Old 12-25-2011, 05:30 PM   #1
I have been 30+ years on single bolt bar clamped stems with few problems.
Looking at new bikes with stems and see 4 bar clamp bolt stems and two bolt clamp with specs on clamping the bolts.
After checking my bike shop over, I see the two bolt bar clamping stems are in my size.
Now with the 2 and 4 bolt systems I feel the need to blue loctight those smaller shorter bolts to feel safe.
loiblb is offline
Old 12-25-2011, 07:12 PM   #2
Likes Given: 2
Loctite does nothing for psi over surface area.
Industry_Hack is online now
Old 12-25-2011, 09:43 PM   #3
Eocyclist
LarryM's Avatar
Hack, I didn't understand that. Are you saying that loctite doesnt' work with short bolts?
LarryM is offline
Old 12-25-2011, 10:43 PM   #4
DX's Biggest Member
CTD50's Avatar
As long as the threads of the stem are engaged -- and most stems have bolts long enough to handily do this -- they don't NEED to be longer.
Blue Loctite is designed to keep threaded fasteners from loosening from vibration and torque, no other reason.
Mountains outta molehills.....
SEZ THE KONA: "AH'M DEAD SEXAY!"
CTD50 is offline
Old 12-26-2011, 04:18 AM   #5
Nail polish makes a good substitute for loctite.
Noel is offline
Old 12-26-2011, 04:30 PM   #6
Likes Given: 2
No, I'm saying that loctite isn't going to affect the clamping force of the bolts across the face of the stem. Technically, it could give you a false reading on your torque wrench, but if they are properly tightened, they shouldn't loosen up. The OP seems to have an issue with clamping area, not the possibility of bolts backing out.
Old 12-26-2011, 05:49 PM   #7
Eocyclist
LarryM's Avatar
I see. Thanks.
LarryM is offline
Old 12-26-2011, 05:54 PM   #8
Likes Given: 2
I ran a two bolt stem on my tandem for a while. With two guys riding, that was around 400 pounds of bike and captain/stoker, which puts a bit of torque on the stem, for sure. No failures, no worries. Shouldn't be a concern on a road bike.
Old 12-27-2011, 03:30 AM   #9
DX's Biggest Member
CTD50's Avatar
I ran RaceFace 2-bolt stems when I ran a 25.4 riser bar on my bike; when I 'stepped up' to 31.8, it was 4-bolt all the way....
I'd like to use that old RF stem again, but I LIKE this new bar so MUCH!
CTD50 is offline
Old 12-27-2011, 01:37 PM   #10
wild's Avatar
I would not use blue, I like purple #222 for small screws in aluminum
wild is offline
Stem Durability and Strength atlantis General Bike Discussion 4 10-24-2011 03:18 AM
Anyone heard of Stem Captain? Industry_Hack General Bike Discussion 47 02-27-2011 10:00 PM
Threadless Stem Jenjabread General Bike Discussion 3 06-29-2009 12:38 AM
