Hi !
I own a Btwin forme 1 , the shifters are grip shifters Sram 3.0 comp and the rear derailleur is a Sram 3(1:1 actuation ration)
I plan to change the grips to trigger, following are the options :
1> Saw this deal, but the actuation ration varies in both
NEW SRAM TRX 7-SPD TRIGGER SHIFTER & X4 Rear Derailleur | eBay.
Is this compatible with each other?
2. Another deal can I use these triggers with my current setup
Sram TRX Trigger Shifter Set at JensonUSA.com
If someone could explain the actuation ratios , i would be grateful.
thks
