Bike and Cycling Forum > Bike Forums > General Bike Discussion > Bike not changing between 3 main gears
Old 10-03-2012, 01:20 AM   #1
albaraptor
albaraptor's Avatar
Liked 11 Times on 4 Posts
Ok so today I did some big hill climbs on my 2007 fuji newest and when I needed to go down or up? To my easier gears it wouldn't shift down. Any ideas on what it could be? Rear derailleur works fine going thru the 8 back there. Only problem is with the front. Any help would be appreciated.
albaraptor is offline
Old 10-03-2012, 01:30 AM   #2
rola643
TwoJ
rola643's Avatar
Liked 4658 Times on 2718 Posts
Likes Given: 4497
So...are you asking about shifting between the front chain rings?
Feel the Burn? That's the sickness and the cure!
rola643 is offline
Old 10-03-2012, 01:46 AM   #3
davereo
davereo's Avatar
Liked 2614 Times on 1438 Posts
Likes Given: 2648
Is the deraileur mounted tightly to the frame?
Is the deraileur dirty?
Is anything caught in it?
When shifting from the large chain rings to the small chain rings the deraileurs movement is controled by the spring.
Is the Spring intact?
davereo is offline
MyBikeWorks Likes This
Old 10-03-2012, 09:14 AM   #4
MyBikeWorks
Liked 63 Times on 39 Posts
Likes Given: 63
As Davereo mentioned, check your derailleur is secured to the frame as if it has dropped/slid lower on the frame it will jam.
The spring that returns the derailleur to the lower gears could be broken.
Is the shift lever working correctly, some older bikes I have worked on recently have a shift lever that is sticking inside and wont release the shift therefore not releasing cable tension allowing the derailleur to swing inwards.
Check to see if you feel/hear a click sound or feel the shift lever engage when shifting up and back down at the front.
MyBikeWorks is offline
Old 10-03-2012, 07:00 PM   #5
SacCyclist
Liked 6 Times on 5 Posts
Also check you cable. If it's stretched and too loose your shifting will suffer.
Don't knock Caribbean Medical Schools - They make many of the people that will patch you up when that old lady opens her door on you.
SacCyclist is offline
Old 10-04-2012, 12:26 AM   #6
Merlincustom
Merlincustom's Avatar
Liked 720 Times on 390 Posts
Likes Given: 212
Front derailleur limit screw may be impeding the travel of the derailleur in the small chainring direction.
Merlincustom is offline
Old 10-04-2012, 12:48 AM   #7
davereo
davereo's Avatar
Likes Given: 2648
Are your cables corroded?
Is the cable jammed in the cable guide beneath the bottom bracket?
davereo is offline
Old 10-04-2012, 03:45 AM   #8
Rock_my_Roll
Rock_my_Roll's Avatar
Liked 172 Times on 117 Posts
Likes Given: 293
Well, hate to admit this, but since it may help you and has an easy solution...
My front derailleur seized on me this summer. My LBS asked me if my electrolyte drink spilled, but I only ever ride with water, so that wasn't it. After a few additional questions we figured out that it was due to my sweat falling onto it and then drying. Was a really hot summer here in the mid-Atlantic area. A bit of hot water, followed by a good drying and some lubricant and I was back in business.
Might want to give that a try if you've not yet solved the problem.
Life's a journey--and I'm just here for the ride.
Rock_my_Roll is offline
larryn Likes This
Old 10-05-2012, 03:50 PM   #9
newleaf150
newleaf150's Avatar
Liked 1822 Times on 1060 Posts
Likes Given: 4144
A bit embarrassing, but great info, and a unique problem source! Great thing to remember. Thank you for sharing it.
newleaf150 is offline
Old 10-05-2012, 08:16 PM   #10
albaraptor
albaraptor's Avatar
Thanks guys ended up taking it to LBS and they fixed it for $8.
Changing forks Mason1990 Mountain Biking 10 10-06-2012 04:49 PM
Help in changing a cassette.... greenhorn Road Bikes 70 12-22-2011 03:58 AM
I am probably changing over to Look Keo2 Max Pedals... baj32161 Road Bikes 12 04-07-2011 03:07 AM
Changing the back tire... am I in for a rude awakening?? fujiyama Beginners Forum 20 05-08-2010 06:49 AM
Newest Threads
