With the faster cadence, your heart has to pump faster to keep those muscles going. A faster cadence is good to use less muscle power, but will only help to a certain point. Your cadence is a lot higher than mine. I can only maintain about 65-70 rpm, but I'm a large guy with a lot of power in my legs. If I get my legs moving that fast, I will be bouncing all over the place and my heart can't pump enough blood to fuel those muscles. The idea behind the faster cadence is to use less muscle power and more mechanical advantage from your gears so you can ride longer. You're just going backwards if you're trying to pedal too fast and can't feed those muscles.
