Originally Posted by ksr5
I have an old Schwinn Letour I am fixing up I put new shifter cables on and believe I have everything adjusted correctly. When I ride in the small sprocket in the back and put pressure on pedals the chain wants to skip or sounds like it wants to change gears. It does not do it in any of the other gears any idea.
If the chain and other parts are new check the chain length. If not the freewheel is probably bad. There is lots of torque on the smallest cog and if the internals of the freewheel are worn you get "skip". More than likely though the freewheel needs to be taken apart, cleaned and lubed.
