Bike and Cycling Forum > Bike Rack > General Bike Discussion > Fixing Brake Cables
Old 06-09-2009, 09:53 PM   #1
Administrator
TxCyclist's Avatar
Fixing Brake Cables
On my bike I loaned to someone, the brake cable has been cut where it goes from the frame to the gyro. Is there any tip for fixing this without taking everything apart? Could I clamp the broken wires together with something then tighten up the rest of the system?
TxCyclist is offline
Old 06-10-2009, 02:50 AM   #2
its worth a try. if it doesn't work, then you know what not to do next time. sometimes its best to learn from your mistakes.
good luck
Don't call me a farmboy, call me a redneck.
bootht99 is offline
Old 12-10-2009, 10:05 AM   #3
craisin's Avatar
I joined 2 gear cables with a electrical connector with the plastic cut off as well as 2 screws holding the lapped cables I put araldite in there too left it for 2 days to set
craisin is offline
Old 12-10-2009, 12:17 PM   #4
♥'s Bicycles
HandsomeRyan's Avatar
since brakes are important for riding safety i would be very careful with homebrew fixes.
HandsomeRyan is offline
Old 12-10-2009, 12:24 PM   #5
Bent Newbie - old rider
Engyo's Avatar
I had both brake cables replaced on my Trek for $15 at the LBS.........this included cable guides.
Namaste, Engyo
2008 Rans V3 - steel steed
1984 Trek 620 - old warhorse
Engyo is offline
Old 12-10-2009, 01:03 PM   #6
craisin's Avatar
good point engyo
my fixes are for the financially challenged.
I wouldnt tie knots in brake cables
but I have tied knots in gear cables and the strands of wire dont share the load evenly and are bound to break constant changes in tension
eventually.
craisin is offline
Brake Questions Bradford BMX / Trials 6 01-02-2010 09:19 PM
Brake upgrade wv-mtneer Mountain Biking 1 12-01-2009 06:55 PM
Fix a Brake Cable Magomra General Bike Discussion 3 08-18-2009 07:59 PM
Brake Levers Kennan Fixed & Singlespeed 3 07-25-2009 01:39 PM
Brake Pads bb-dan General Bike Discussion 2 06-12-2009 12:32 AM
