Bike and Cycling Forum > Bike Rack > General Bike Discussion > Front Brakes
Old 05-26-2009, 06:09 PM   #1
Front Brakes
I recently installed a set of Avids on a friends bike...he is complaining about the brakes pulsating whenever he uses his front brake...is this due to the rim being a tad out of true? Any suggestions on how to get rid of this problem?
Thanks from me and him!
bb-dan is offline
Old 05-26-2009, 06:20 PM   #2
Doc
Doc's Avatar
Are the rotors running true?
Doc is offline
Old 06-05-2009, 03:30 PM   #3
the wheel being out of true can cause brake pulsations. Another good posibility is oils, dirt, grease or some other contaminates on the rim/rotor depending on wether it's rim or disc brakes.
BigDumbBear is offline
Old 06-12-2009, 12:40 AM   #4
If it is a disc brake the rim being out of true has nothing to do with it since the rotor is mounted to the hub. If it is a v-brake and the rim is out of true then you would definetely feel it some. Make sure all the bolts are tight too.
tajcrews is offline
Advice on Front Panniers? Cyclomatic Mountain Biking 3 11-03-2009 11:26 AM
Front/Back rim interchangeability? Bobby_M Mountain Biking 2 07-03-2009 01:27 AM
Front shock lube TheMan Mountain Biking 4 06-18-2009 09:09 PM
Need new front shock FOXshox Mountain Biking 10 06-11-2009 11:41 PM
