Bike and Cycling Forum > Bike Rack > General Bike Discussion > How do you properly lube a chain?
Old 05-04-2009, 05:08 AM   #1
Doobie's Avatar
I have been told by those in bike shops that you need to remove the chain from the derailleur and sprockets to properly lube it. They said to place it in a bucket with a Cleaning and lubing solution to get rid of grease and debris.
This seems a little too extensive for just a routine maintenance kind of thing.
What do the rest of you think?
Doobie is offline
Old 05-04-2009, 07:24 PM   #2
littleblackxj's Avatar
Eh, it probably is for "pro-riders". Me personally, I just tip my bike upside down, turn the crankshaft and spray the chain with some clear chain lube. The lube I use is meant for motorcycles, but it works great for my bike
littleblackxj is offline
Old 05-20-2009, 06:57 AM   #3
Doobie's Avatar
I went out and got some T-9 lube, stuff works great. Doesn't clog the chain and keeps the dirt from sticking.
"Its all down hill after this......."
Only sounds good to those who ride
Doobie is offline
Old 05-20-2009, 04:19 PM   #4
Doc
Doc's Avatar
Sounds interesting man, are you using anything special to apply it with?
Doc is offline
Old 06-04-2009, 10:41 PM   #5
gnar! gnar! gnar!
cbman's Avatar
The right way
You're supposed to remove the chain, wash it in warm water/ solvent, soak the chain in oil overnight, then the next day hang the chain up to dry until excess oil is removed. After that you either reinstall it or (if you're going to store the chain) wrap it in some wax paper.
cbman is offline
Old 06-04-2009, 11:49 PM   #6
Doc
Doc's Avatar
Thanks for the information there, I never actually thought of completely removing the chain to lube it up. I will give it a try.
Doc is offline
Old 06-08-2009, 07:13 PM   #7
Liked 2 Times on 2 Posts
I have been using Rock & Roll lube. It cleans and lubricates the chain on the bike in one operation. Basically, you just freewheel the chain backwards while applying a stream of R&R. Wipe off the excess and go ride your bike. It's simple and works very well.
Old 06-18-2009, 09:14 PM   #8
Neuner's Avatar
Same here only I use White Lithium Grease. Spray it on the chain & cassette before every ride. Never had an issue. I replace my chain every year. I don't have cassette damage either due to 'chain growth' wear & tear.
Neuner is offline
Old 06-18-2009, 09:52 PM   #9
There really is only one way to properly clean & lube a chain.
Old 07-01-2009, 02:14 PM   #10
Before using the method in the post above please be aware that in europe the possesion and use of:
Shelbroconol Pre-soak
Shelbrothane Cleaning Solvent
Deakinol Rinsing Solvent
Is illegal under the new antiterrorist legislation.
I believe that it is also illegal to use these in most of the USA except Utah and Texas.
Roguefx is offline
Honda chain lube test trial snowbird General Bike Discussion 12 01-11-2010 01:29 PM
Chain lube wild General Bike Discussion 30 10-21-2009 01:59 AM
Anybody here use White lightning wax base chain lube? Mike1jw General Bike Discussion 10 10-08-2009 08:55 PM
shifting gears properly johnny Beginners Forum 21 10-07-2009 04:43 PM
Rohloff chain lube peaches General Bike Discussion 0 07-03-2009 06:32 PM
