Britain LEJOG
I did the trip in May 09, 932 miles. Don't worry too much, it's not that difficult. If you are reasonably fit you should not have problems and after 2 or 3 days you'll be fit anyway.
Will you be assisted or carrying all your own bags? If the latter, keep it all as small and as light as possible! I stayed B&B which gives you the facilities off the bike that make a big difference, particularly if you encounter bad weather. I had rain for 10 days so needed to dry out after each day!
Check the CTC Blog for LEJOG (Lands End to John O'Groats), lots of help and advice from seasoned LEJOGers is posted.
I'm planning C2C this year. Only about 140miles but I'm trianing for a marathon run in September so will be using cycling as cross training!!
BTW, I'm 64!!
Best wishes Malc.
