Bike and Cycling Forum > Bike Rack > General Bike Discussion > Modern Chains
Old 01-10-2012, 09:46 PM   #1
Modern Chains
Many years ago (50 - 60 years ago), when I worked on my bike the chains had a built in disconnect link. Bend the chain and remove the outside plate and pull the pins. Chain came off and made easy work of working on the crank and/or rear coaster brake assembly.
Do the chains for modern multi speed bikes have the disconnect link like old days?
Possumpoint is offline
Old 01-10-2012, 09:57 PM   #2
Liked 4 Times on 4 Posts
Likes Given: 5
They were not common on quality bike chains for many years but thankfully, master links have returned! I use Sram Powerlink chains.
qmsdc15 is online now
Old 01-10-2012, 10:38 PM   #3
Also Shimano chains.
Noel is offline
Old 01-10-2012, 11:05 PM   #4
Likes Given: 5
Yeah? I know Shimano chains of recent vintage require a special rivet to re-connect, but I didn't know Shimano chains now use a master link. If so, they're late to the game, but better late than never!
Old 01-11-2012, 12:35 AM   #5
TwoJ
rola643's Avatar
Liked 5 Times on 5 Posts
Likes Given: 8
I use the SRAM PC1071 and for me it's easeir to treat it like a Shimano chain. I have never been able to get a Powelock apart, I think they make an app for that
I'm guessing the powerlink is different than the Powerlock?
rola643 is offline
Old 01-11-2012, 11:40 AM   #6
Likes Given: 5
Treating like a Shimano chain as in using a chain tool to break and a Shimano connecting rivet to rejoin?
Powerlock is the master link on Sram's ten speed chains. I'm not sure how they differ from the Powerlinks I'm familiar with.
A neat trick for opening Powerlinks here: http://www.ctc.org.uk/resources/Magazine/201107050.pdf
It works great!
Old 01-11-2012, 12:02 PM   #7
Thanks for all the replies, especially the hint on how to disconnect the Powerlinks qmsdc15. Now when the weather is warmer, I'll go check and see what chain is on my 21 speed Schwinn.
Old 01-11-2012, 12:35 PM   #8
TwoJ
rola643's Avatar
Likes Given: 8
It works great!
Edit. I see same chain-link, my bad! I have tried 1/2 heartily to remove and gave up. So yes I use a chain tool to a replace the hollow pin with a Shimano 10 speed pin. I've asked before if it was safe to do. I think the dimensions are the same and it's just a weight difference, I hope
Per SRAMS Technical manual PDF the Power lock is for one time use and must be removed with a chain tool.
" Once the Powerlock has been installed It can only be removed by means of a chain tool."
http://www.sram.com/sites/default/files/techdocs/my10-sram-tech-manual-rev-a.pdf
rola643 is offline
Old 01-11-2012, 01:58 PM   #9
wild's Avatar
Park tool makes a set of pliers that make power link, speed link removal a breez
wild is offline
Old 01-11-2012, 05:54 PM   #10
Oh boy a new tool I can buy! I'm not being ironic.
Noel is offline
Modern Warfare 2 Xela Off Topic 13 11-10-2009 08:35 PM
