pedal problems
Old 12-24-2012, 01:33 PM   #1
type36
Liked 16 Times on 7 Posts
Likes Given: 7
pedal problems
About 4 months ago, I had a pedal/shoe fitting on my hybrid.The LBS did the pedal install.
Thinking about selling the hybrid, as I have bought a roadie. Went to put the stock pedals back, the right one is seized - yes I know they are handed. The pedal is so seized that my Park pedal tool is rounding out. Any tips? Really would hate to mutilate something.
Mike
type36 is offline
Old 12-24-2012, 02:17 PM   #2
HillDancer
Bayou Biker
Liked 454 Times on 218 Posts
Likes Given: 11
Penetrating oil, gravity, and time. Use a lube like PB blaster or true penetrating oil, lay the bike on its side, apply lube a couple times a day over a few days. Leverage also helps; find a way to lock the crank arm while applying force to the pedal.
HillDancer is offline
Old 12-24-2012, 02:29 PM   #3
carlharsch
Senile Member
carlharsch's Avatar
Liked 1420 Times on 649 Posts
Likes Given: 466
You sure the pedals weren't installed using an allen head bolt inside the crank arm? I know that's how my Shimano pedals are installed/removed.
carlharsch is offline
Old 12-25-2012, 10:55 AM   #4
wild
wild's Avatar
Liked 3461 Times on 1441 Posts
Likes Given: 1134
Try tightining first then unscrew that will some time do it. You should try a better wrench allso maybe a crow foot with a braker bar, and BP Blaster
My
wild is offline
Old 12-26-2012, 09:14 AM   #5
retromike3
retromike3
Liked 77 Times on 37 Posts
one thing to try
One thing you might try is to take the crank arm off. after that find a vice and put that sucker on there. Chances are that you will be able to exert a bit more pressure on it that way.
Is it possible that you might have installed the wrong pedal? I've done that myself on customers Bike and had to rebuild the threads within the insert. lucky for me the process works pretty well and I haven't gotten any complaints from him yet.
The main problem I find with petals is that inserting a threaded steel shank into aluminum whole. Added to that, most petal wrenches will give you an awful lot of force which can make things go bad fast.
What I should do is to thread the pedal in with a standard wrench or just my fingers and then use the big wrench to tighten it down. Its kind of hard to cross thread of pedal with just your fingers.
mike Frye A.K.A. Frye Bikes
retromike3 is offline
Gear Change Problems mercurious Beginners Forum 0 05-17-2011 02:58 PM
Shifting Problems cvgreg Beginners Forum 10 05-08-2010 03:00 AM
Best cycling shoes for foot problems Grape Ape Gear & Accessories 8 01-26-2010 03:37 AM
Thyroid problems. Anyone else have them? Michigander Training / Health 18 12-23-2009 11:02 PM
Drive Train Problems snowman69 Mountain Biking 1 08-06-2009 09:58 PM
