Originally Posted by BIGPBS
1. Can you mount a shimano centerlock disc brake rotor on a Terramax wheel? If not why!!
I don't think so. I couldn't find much info online about that wheel but since it isn't labeled as a centerlock hub I would assume it's a standard 6 bolt.
2. We have a broken rear mountain bike rear derailleur. It is a long cage sram x.5 can you replace it with a long cage Shimano XT?
Can you replace it with a long cage sram x.9?
You can straight replace the x9 for the x5 and this is generally considered t be a pretty decent upgrade. I do not believe the SRAM shifter is compatible with the Shimano derailleur (although you might double check as I could be wrong). In other news- My mtb runs the XT and i've been quite happy with it.
3. can you use a UST tubless tire with a non-tubless wheel?
If you can how?
I think you need a kit like
this.
I'm not an expert on any of these things but I've never let that stop me from offering my $0.02.
