Bike and Cycling Forum > Bike Rack > General Bike Discussion > Replace shifter or derailer?
Old 07-21-2009, 06:17 PM   #1
I need to know if I should replace the shifter or the derailer. I did have the entire bicycle recently over hauled by a local shop after it was given to me from my family.
Some information first...
1996 Diamondback WCF 4.0
Shimano Derailer - I can get the specific model later.
Grip Shift shifter
The shifter feels a bit loose. Some times if I hear the chain popping from be misaligned I can slightly move the shifter with out changing gears and that fixes it. Some times it will even pop over to nearby gears with out shifting as well.
I will post some pictures later tonight.
Alexia is offline   Reply With Quote
Old 07-21-2009, 06:30 PM   #2
Moderator & beer geek
What did your local shop do as part of the overhaul, specifically to the drivetrain?
hophead is online now   Reply With Quote
Old 07-21-2009, 06:35 PM   #3
Tighten, adjust, grease, etcetera. I know how to do it myself, but it was faster for them to do it. It had the same issue before I hauled it in there for service. They did not make any recommendations for replacing any parts though.
Old 07-21-2009, 07:27 PM   #4
It sounds like your problem may be worn drivetrain components rather than shifters & derailleurs. Check the teeth of your chainrings & cogs for wear. Also, check your chain. If you don't have a chain checking tool you can use a ruler. The pins are spaced 1/2' on center. If you measure a 12" span the first and last pins will be exactly 12" apart on center. If it's 1/8" or more over, the chain is wasted.
A new chain will look like this:
Old 07-21-2009, 10:09 PM   #5
I checked the chain. It is off by one to two millimeters. I did some additional testing and it seems the most trouble is trying to shift down past fourth into 3/2/1 with me needing to push it a little past to fully engage the shift. It has an easier time going back from first to fourth though.
I will replace the chain and will probably replace the shifter as well. I do prefer the thumb toggle shifters and not the grip shifters.
Tubes: Patch or Replace? HandsomeRyan General Bike Discussion 29 06-07-2010 12:00 AM
When to replace tires? tydale Road Bikes 13 10-24-2009 06:49 PM
trigger shifter wild General Bike Discussion 6 08-26-2009 11:55 PM
Looking for a new rear derailer Roadhero General Bike Discussion 2 06-08-2009 08:03 PM
  • rss
  • facebook
  • twitter
