Bike and Cycling Forum > Bike Rack > General Bike Discussion > road bike hub laced to a fixed gear rim?
Old 10-28-2011, 03:51 AM   #1
can this be done?I was wondering if i can put a 130mm 36 hole hub on my tec9 43mm deep v rims,
thanks,
luis
deleon87 is offline
Old 10-28-2011, 11:50 AM   #2
Liked 318 Times on 193 Posts
Likes Given: 868
Sure, why not?
qmsdc15 is offline
Old 10-28-2011, 12:05 PM   #3
Vendor
PlatyPius's Avatar
Liked 17 Times on 15 Posts
Likes Given: 1
A hub is a hub. As long as the number of holes matches, anything will work. Differing numbers of holes can be accommodated for, but it's better to have them match.
Got Coffee? Get some great coffee sold by a cyclist for cyclists. Amazing! Coffee that doesn't taste like gasoline! http://www.rapidoroast.com
Disclaimer: I own a bike shop. Yes, I'm biased and opinionated.
PlatyPius is offline
Old 10-28-2011, 02:07 PM   #4
Liked 1993 Times on 1316 Posts
Likes Given: 2207
How are you planning on stopping?
Old 10-28-2011, 06:54 PM   #5
Vendor
PlatyPius's Avatar
Likes Given: 1
The 43mm Tec 9 rims, AFAIK, have a machined braking surface.
Of course, hipsters don't like brakes anyway. And general society prefers that they don't have brakes ... so that we can nip that offshoot of the genetic tree in the bud before it pollutes the future.
Old 10-28-2011, 09:04 PM   #6
thanks guys , I'm new at this so I didn't know, all hubs have the same width, where the spokes attach. it's the axle that varies. right?
deleon87 is offline
Old 10-28-2011, 10:17 PM   #7
Vendor
PlatyPius's Avatar
Likes Given: 1
There are a million or so combinations out there. Hub flange diameters differ, flange spacing from center varies, etc. Plus, track hubs are usually 120mm width and road hubs are 130mm width for the rear.
ie: if you're thinking about reusing your spokes, it's almost guaranteed to be impossible.
Old 10-28-2011, 10:24 PM   #8
Likes Given: 2207
If he's going from a small hub to a large ones, and writes Phil Wood a sizable check, it's easy. And I think Tec 9 rims are also available without a machined brake surface.
Old 10-28-2011, 10:42 PM   #9
Likes Given: 868
I don't get the comment about paying Phil Woods (to shorten the spokes?) but I think it was a snarky wisecrack anyway, not to be taken seriously. Whether or not your rims are compatible with rim brakes is indeed something to consider. I don't think rims need to be machined, as long as they have a flat surface that the brake pads can align with. Platypus and Industry Hack know more than me about that sort of thing, so listen to them. Although one of them seems unwilling to explain himself in a way that a neophyte can understand, maybe he will make himself clear.
"How are you planning on stopping?"
Is this a riddle, Socrates? deleon has made clear that he isn't knowledgeable about bikes. Do you want to help him or just ask him confusing questions?
qmsdc15 is offline
Old 10-29-2011, 02:01 AM   #10
yes the rims are machined for brakes. I curently use brakes front and back with them, and as far as the spokes, I kinda figured i wasn't going to be able to reuse them. I really like the wheels although haven't tried too many to compare, I like them. another question would be do spokes for a 700c rim come in different lenghts?
deleon87 is offline
Fixed Gear Back to 7 Speed DaleDenton Fixed & Singlespeed 4 12-05-2009 01:34 AM
Fixed gear to IGH conversion... HandsomeRyan Fixed & Singlespeed 5 09-25-2009 09:49 PM
