Save what sanity I have left with a brake issue
Old 01-26-2013, 09:35 PM   #1
kneedrachen
kneedrachen's Avatar
Liked 7725 Times on 3710 Posts
Likes Given: 14143
Cannot for the life of me figure this one out. MY google-fu turns up no useful information.
105 dual pivot calipers, during a drivetrain cleaning I lubed the pivot points with tri-flow. Was a bit, eh, heavy handed with the tri-flow.
Anyway, once I had everything buttoned up, squeezed the rear brake a few times, nice and silky smooth.
Bike sat for a week and was working on another bike and just to see if it the brake was a smooth as before, squeezed the lever and was getting a clicking noise with resistance in the lever. Hmm. The brake didn't feel as smooth at all.
Did some poking around and the noise is most likely coming from the caliper; it sounds like the spring is clicking. Before I go through with a caliper dissasembly, is it plausible that the spring is dislodged in it 2 contact point housings?
I checked the mounting bolt, all is tight, cable seems to be okay where it enters the rear housing.....
Google only turns up brake squeal and didn't have much luck with Sheldon's site or Park Tool. . . .
thanks in advance.
kneedrachen is offline
Old 01-26-2013, 10:01 PM   #2
davereo
davereo's Avatar
Liked 5847 Times on 2774 Posts
Likes Given: 6088
Is the little black bushing that the spring goes through still intact?
I lube my calipers (105) everytime I lube my chain and have never had that issue.
Once this is resolved please share.
John Heisman
davereo is offline
Old 01-27-2013, 01:02 AM   #3
kneedrachen
Likes Given: 14143
Dave-
pretty close to the mark.
I solved it in about 3 minutes once I cleared my head.
I had pulled the brake cable out of the stop, slid the housing around, lubed it etc and then operated the caliper by hand and it was still making the noise. I also did the same there where the housing meets the caliper along with the rear barrel nut adjuster. I was pretty sure that I now had eliminated the cable at this point in time as the culprit.
I was 99.9% sure that it was the spring, just not sure what it was with the spring. I ended up feelng with my right hand a sort of "grind/grit" sensation when the caliper moved. Being that I am not hesitant to ride my bike in less than ideal condition (sucky pavement, bad weather, questionable surfaces) I was convinced there had to be some kind of grit somewhere in the caliper mechanism. I cleaned out the pivot points with no results so I ended up dripping some WD40 through the top of the black plastic spring bushing, squeezed the caliper a few times and presto, no more noise. I followed up with 2 drop of lube and all is good.
I had a bazillion miles on my Synapse (Tektro brakes as it was a Synapse 5 alloy) and never, ever had that problem (but also only rode it when it was picture perfect outside minus temperature). So, lesson learned and gained some experience in the process.
4
Old 01-27-2013, 03:29 AM   #4
Merlincustom
Merlincustom's Avatar
Liked 1526 Times on 716 Posts
Likes Given: 454
Before you solved it, I was about to say the brake went into anaphylactic shock from OD'ing on tri-flow. Do you think the excess tri-flow flushed the grit to where it got lodged where you could hear/feel it?
Merlincustom is offline
Industry_Hack Likes This
Old 01-27-2013, 09:15 PM   #5
kneedrachen
Likes Given: 14143
Merlin-
Without a doubt. Not havin ga rear fender and riding through a bunch of junk certainly allowed a lot of grime and grit to get in there. I flushed the caliper first with water and then some isopropryl alcohol, the triflow, rather than using a dripper bottle i used my aerosol can sans straw.
What I didn't realize inthe beginning was that the arm of the spring slides through that plastic bushing, once I saw that it dawned on me.
Old 01-27-2013, 09:20 PM   #6
Merlincustom
Likes Given: 454
Raceblade Long fenders are pretty nice.
Old 01-27-2013, 09:28 PM   #7
kneedrachen
Likes Given: 14143
actually have a set of raceblades on order; the PDW Full Metal Fenders won't fit my frame due to the tight clearance between the "chainstay bridge" and my tire on the TCR; the raceblades should do the trick.
Save me from the Wal-Mart bikes, please! Industry_Hack General Bike Discussion 11 09-24-2012 03:31 AM
Save the bike! rola643 General Bike Discussion 1 06-28-2012 10:08 AM
Spend or save rola643 General Bike Discussion 7 11-04-2011 02:06 AM
Save ! rola643 Off Topic 4 11-16-2010 06:13 PM
How do I run brake housing with aero brake levers, the cable runs from underneath?? fujiyama General Bike Discussion 0 05-30-2010 04:21 PM
