06-29-2011, 11:21 PM
Tar
I'm riding a trail just to avoid this problem. They're fixing cracks in the asphalt trail with hot tar. On the way out I dismount because the truck is taking the whole 10 ft wide trail. On the way in, heck, I can negotiate the 8 in. next to a real soft shoulder, right?
Pass the truck, ride over fresh tar and then lose the road and both tires are covered in tar and dirt and rocks and , ugh!!
It's like i was tarred and feathered!! Anyone have any ideas on what I can do short of buying 2 new tires? Thanks all.
06-30-2011, 12:33 AM
Liked 6 Times on 5 Posts Likes Given: 2
I can only suggest 'Simple Green" and elbow grease. Then a good rinsing. Good luck.
I have been crucified with Christ and I no longer live, but Christ lives in me. The life I now live in the body, I live by faith in the Son of God, who loved me and gave himself for me. Gal 2:20
06-30-2011, 04:13 AM
Actually you might try WD 40. I have used it to degrease many things. Just don't use it on your chain. Its a solvent not a lube.
06-30-2011, 04:33 AM
1. WD40 to clean the tar off of what ever it is stuck to.
2. Simple Green and clean water to wash your entire bike. It probably needs it anyway and by the time you get done with the WD40 it will need it because of over spray.
3. Put bike on your external bike rack and drive at least 10 miles on a highway or freeway to dry the bike.
4. Re-lube with your preferred lubricant.
06-30-2011, 04:32 PM
I've had great luck with Goo Gone.
07-01-2011, 10:35 AM
I use WD40 then wash and dry with leaf blower
07-01-2011, 02:02 PM
WD did the trick. Used a scraper, gingerly, and the tar came right off. Going to get some Simple Green and wash the tires with that.
If the WD didn't work, Goo-Gone was next.
If WD-40 is a solvent and not a lubricant, can anyone recommend a good aerosol lubricant? Thanks for all the help.
07-01-2011, 02:10 PM
TwoJ
Liked 4 Times on 4 Posts Likes Given: 4
Kerosene for heavy duty removal
I spent half of my life riding bikes. The other half I wasted.
07-02-2011, 08:37 PM
Giant brand Liquid Silk.
07-03-2011, 07:28 AM
#10
I use Finish Line Wax Lubricant, in a drip bottle. The LBS that I go to most often carries and also recommends GT-85. But if you're worried at all about the environment than a drip or pump bottle is the better way to go.
Also just a little trivia but WD-40 stands for "Water Displacement formula number 40." What I'd like to know is what happened with formula's 1 - 39?
