Bike and Cycling Forum > Bike Rack > General Bike Discussion > Tips & Tricks
Old 07-06-2012, 01:43 PM   #1
Xela's Avatar
Liked 703 Times on 388 Posts
Likes Given: 646
Tips & Tricks
Here is a thread for us to post tips and tricks and bits of wisdom that we have learned over our years of riding. What seems obvious to you might be a hidden gem of knowledge to others.
I realized this the other night on a group ride when a rider dropped his chain and pulled over.
If you drop your chain to the inside on a downshift and have some speed to spare, oftentimes you can shift the front derailleur up to the big ring and it will push the chain back on and you can keep rolling.
Xela is online now
4
Old 07-06-2012, 04:07 PM   #2
John_V's Avatar
Liked 821 Times on 524 Posts
Likes Given: 241
A secondary deterrent to someone wanting to steal your bike is to put a regular padlock on your crankset through one of the ring openings and around the chain. If the shackle fits tightly around the chain the ring, it makes it much more difficult for anyone to cut the lock without totally destroying the chainring. Most thieves that steal bikes want to get rid of them quick. Taking the time to mess with cutting the lock that close to the chainring and damaging the bike will make most of them think a little before snatching it. Plus, a pawn shop won't take it with a padlock on the chainring.
HCFR Cycling Team
2012 Colnago Ace
2010 Giant Cypress
http://www.pedalmybike.com/userTrack...rackie4389.jpg
John_V is online now
5
Old 07-06-2012, 04:38 PM   #3
Shawn's Avatar
Liked 9 Times on 6 Posts
Likes Given: 7
My tip for newbies is to get to know your gears. At first, I never messed with mine because what gear it was in was the best for me then I started messing with them more and figured out I could go a lot faster lol. My friend wont mess with his at all and he claims I am cheating when I go faster than him because I am using my gears, haha.
Shawn J. Gossman
2012 Trek 1.1 Road Bike
2012 Gravity Base Camp 2.0 MTB
Addicted to cycling - addicted to storm chasing - addicted to photography
Shawn is offline
Old 07-08-2012, 06:07 PM   #4
newleaf150's Avatar
Liked 1026 Times on 647 Posts
Likes Given: 2657
Great idea for a thread, Xela!
+1 to Shawn's comment on gears. They are there for a reason. Learn not only to use them, but also how NOT to use them. Trying to shift between front rings under full power, for example, will not work well at best, and will leave you stranded with your chain stuck between the rings at worst.
Anticipate the need for a lower gear and make your shift before you're straining to climb the hill. Later, learn to shift while climbing by spinning the cranks with very little 'torque' just long enough to catch the next ring, but before you lose all your momentum and fall over Don't forget that your derailleurs have VERY little 'power' to work with in making a shift. Your push of a thumb, twist of a wrist, etc. is all the energy they have available. It isn't much next to your legs.
Clean your chain regularly and keep it well-lubed. Too much lube is as bad as too little here. A little bit goes a long way. A properly-lubed chain reduces mechanical drag and lets you put more of your pedal-stroke toward moving yourself and the bike forward rather than working to circulate the chain. It goes without saying that the chain will last longer when it's properly lubed. If you notice squeaking out of your drivetrain while riding, it's probably been too long. Stop. Oil your chain.
Adjust. Your. Seat. Height. Please. Doing so will literally make you a stronger rider. When your seat is too low, you aren't giving the muscles in your legs the ability to fully engage the cranks to move you forward. A too-low seat also puts inappropriate stress on your knees. Over time, this can damage them badly. It takes time to get seat height dialed in perfectly, but you should see an immediate gain in power and comfort from even gross adjustments. That said, too high is just as bad, if for different reasons, as is too low.
Never leave home without at least a patch kit, pump and preferably also a spare tube. If you run 'slime' or one of its analogs, forget the patch kit and just carry a spare tube - some road debris will take out your slimed tube like it's not even there. It's great to not have to walk when this happens, as it did to me just this weekend - I never saw what it was, but hit something that left a 1/4" gash through both the outside and inside of my tube. Slime or no, that one's done.
Even if you're not a 'slime' person, this kind of situation is why it's wise to still carry a spare tube in addition to the patch kit. You (hopefully) won't need the spare tube often either way, but when you do, it makes up for all the miles you've carried it. Your experience may vary. Don't forget your tire levers I count them as part of the patch kit.
newleaf150 is online now
Xela Likes This
Old 07-08-2012, 08:02 PM   #5
lmiles64's Avatar
Liked 202 Times on 125 Posts
Likes Given: 281
Amen bother!
"Ride More in 2013"
lmiles64 is offline
Old 07-08-2012, 08:05 PM   #6
lmiles64's Avatar
Likes Given: 281
Okay. I noticed a little problem I'm having recently with my gloves. Sweat. The sweat between my hands and the gloves makes for a slippery situation.
Has anyone ever used baby powder and talcum powder inside their gloves to combat this problem. Seem it would work for a while, but would it hold up over a 50+ mile ride?
"Ride More in 2013"
lmiles64 is offline
Old 07-08-2012, 09:43 PM   #7
TwoJ
rola643's Avatar
Liked 2098 Times on 1354 Posts
Likes Given: 2520
Paying 12 bucks for Camelbak cleaning tablets for a package of 8 really??? Aint happening with this happy camper! Efferdent Power Clean Crystals ( 48 packets for 5 bux! )are the ticket!! These handy packets work well in stubborn bottles as well. I use well water so that can be an issue.
rola643 is offline
newleaf150 Likes This
Old 07-08-2012, 09:46 PM   #8
TwoJ
rola643's Avatar
Likes Given: 2520
Paying big bucks for Sports clothes cleaning products to keep them fresh and odor free?? Not me!! A dash of Arm & Hammer baking soda when you wash those kits works miracles!!!
rola643 is offline
Old 07-08-2012, 10:14 PM   #9
Xela's Avatar
Likes Given: 646
With all the synthetic materials in our bike clothes, there's usually not a option for wiping your glasses mid-ride as sweat and grime build up. A simple squirt from your water bottle does a great job at getting the lenses clean(ish).
Xela is online now
Old 07-08-2012, 10:46 PM   #10
Liked 1990 Times on 1313 Posts
Likes Given: 2207
Keep the rubber side down.
6
I found in my box of tricks a dynamo,does anybody know the output voltage craisin Beginners Forum 6 12-29-2009 11:28 PM
Mtn Bike Tricks and Wrecks Xela Mountain Biking 7 09-17-2009 05:35 PM
Air Tricks McGruff BMX / Trials 2 07-22-2009 07:48 PM
Craziest Tricks Seen on Trail You Made Sludge Off Topic 1 06-30-2009 12:18 AM
