Bike and Cycling Forum > Bike Rack > General Bike Discussion > Tire Tubes
Old 08-13-2009, 09:33 PM   #1
Tire Tubes
Which tire tubes work the best? I have tried a lot of different kinds and I even tried that goop stuff and I am still keep getting flats....
bakers is offline
Old 08-14-2009, 12:08 AM   #2
gnar! gnar! gnar!
cbman's Avatar
What kind of riding do you do? You may have a hole in the tire, allowing sticks and stuff to pop the inner tube easily. There could also be something very small stuck on the inside of the tire, popping the tube. If It's popping and your doing heavy duty off road riding you may need a thicker tire. Bontrager sells a version of the connection trail that is double the thickness of a normal tire. I use Bontrager tubes in all my bikes, they're great.
Let us see...
what bike part shall we order this week?:rolleyes:
cbman is offline
Old 08-14-2009, 05:00 AM   #3
Administrator
TxCyclist's Avatar
There are flat free tubes as well if you want to chance running those.
Unanswered Threads
TxCyclist is offline
Old 08-14-2009, 05:49 AM   #4
SMILEY CAR
Tarukai's Avatar
check to see if the tubes are getting punctured on the inside (the side against the rim/nipple strip), or the outside (the tire side). If it's on the inside, then it's an issue with the spoke nipples being exposed somewhere, not the tubes themselves. If it's the outer side, check for holes in the tire.
Tarukai is offline
Old 08-14-2009, 03:46 PM   #5
Run your finger along the inside of the tire also. If your tube and tire are being set correctly, it could be a thorn or piece of glass. Often, you can't even see them, but they will still puncture a tube.
runbikeswim is offline
Old 08-14-2009, 08:21 PM   #6
Younger than Hack
Grape Ape's Avatar
Better way to check the inside of your tire than just feeling with your hand is to get a few cotton balls and wipe the inside of the tire with them. The cotton balls will catch the intrusion and snag showing you where it is, while protecting your hands from a cut from glass or a thorn. The cotton swabs can be added to your tool kit without adding any weight so you have it available while out riding.
Grape Ape is offline
Old 08-14-2009, 08:50 PM   #7
Is your tube getting punctured or are you getting pinch flats? If you are getting pinch flats, use more pressure.
Tubes: Patch or Replace? HandsomeRyan General Bike Discussion 29 06-06-2010 11:00 PM
Pros & Cons of OS Tubes? MFG_bike Road Bikes 3 10-20-2009 06:36 PM
What Tubes TxCyclist Mountain Biking 3 09-14-2009 09:22 PM
Fat Tire Ale Jenjabread General Bike Discussion 18 08-27-2009 08:53 PM
Off Road Tubes? JamieDamnGarrett Tires / Wheels 9 07-28-2009 05:21 AM
