Bike and Cycling Forum > Bike Rack > General Bike Discussion > What would cause a random tire blow out?
Old 11-09-2009, 08:20 PM   #1
roy
As I've talked about I'm a big guy biking to lose weight. I was on the road about a quarter of a mile from my house and I had a blow out. I was worried it was a weight issue but I'm thinking not. It just blew out. Any idea what could cause this? I called my bike shop and they said it could be a rim issue,but then they tried to sell me on tubeless. Are tubeless better under pressure?
roy
roy is offline
Old 11-09-2009, 11:13 PM   #2
Group rookie
djcyberlegend's Avatar
re: What would cause a random tire blow out?
A number of different things can cause a blowout. How old was the tube that blew?
Newest ride: 2000 KHS Flite 300
MOD @ My main hangout
Follow me on TWITTER
Facebook - MySpace
"I have no karma - I had to get rid of my karma, because it runned over my dogma..."
djcyberlegend is offline
Old 11-10-2009, 12:40 AM   #3
DX's Biggest Member
CTD50's Avatar
Need more info, roy -- yup, age of tube CAN be a factor, but how about the bike? Type, wheel/tire size, pressure you were running, etc. A few of us can CSI that stuff pretty well.
CTD50 is offline
Old 11-10-2009, 03:56 AM   #4
Was the tire blowout an actual tear in the tire or was it a hole in the tube?
eaton is offline
Old 06-25-2011, 01:06 PM   #5
yes roy, you can try yourself to fix up it, & get on the way to solve this actual issue .
hartley1 is offline
Old 06-25-2011, 03:01 PM   #6
Roy though they can blow out, and age of the tire and many things can affect that, I'd put my money on that it was cut and not a blow out. What happens on a bike can be the exact same experience.
A small piece of glass in the road, a thorn, or any of a number of things sharp can make a small cut and wha la you have a rapid loss of tire pressure followed by that sinking feeling that you know you are riding on the rim.
The first thing I would check is the inside of the rim and tire. Gently rub your fingers inside the wheel and tire to feel for anything sharp. Remember there could be something in there that cut a tire so it could cut you too, so be careful. Yet anything rough should be readily apparent and that could be the source of your issue. The end of a spoke could be an issue and don't forget to check the rim tape.
photosbymark is offline
Old 06-25-2011, 08:56 PM   #7
SUX VR40 Rider's Avatar
The only way to answer the OP's question is to make a list and throw a dart. Several things, some if combined together and some not.
SUX VR40 Rider is online now
Old 06-25-2011, 11:10 PM   #8
If you're riding regularly you should expect several flats this summer. Last summer I had a ton, a couple of times I had several in one ride. And yes I carefully check each occurance...sometimes they just happen. This year I haven't had any...yet. The important thing is to have the proper tools and spares, and the knowledge of how to change out a tube.
One good hint: when the flat occurs on the real wheel, shift down to the little cog before removing the wheel. Makes it much easier to get on/off.
robkyle is offline
Old 06-26-2011, 12:16 PM   #9
wild's Avatar
There are a lot that can cause a blow out low air presure is one, a cut tire is anouther, a pinch flat where the tube is pinched between the tire and the rim, snake bite. The last time I had a pinch flat I put a patch over the two holes and then I found a small leak in anouther spot. Conclusion was small leak, then when the tire got low enugh pinch flat. Bt the way if you are getting a lot of flats I like tire liners thay seam to help.
my.02
wild is offline
Old 07-04-2011, 11:21 PM   #10
If I were a bettin' man, I'd go for the pinched tube. If the blowout was accompanied by a report (bang!) then it's either a tire failure or a pinched tube. Other flat modes may cause rapid deflation but rarely sound like gunshots.
Two tire failures can cause blowouts: cord failure, in which case the tire itself will have a gaping hole in it, or bead failure, in which case putting it back on the rim will be too easy and the tire will fit loosely.
A pinched tube is the result of improper installation, causing the tube to get caught (pinched) between the rim and the tire bead. One guy in my riding group had a slew of blowouts, which continued until a couple of us who knew what we were doing finally pushed him aside and made him watch while we replaced his tubes. Hopefully that's the end of the issue for him, until he replaces his tires at any rate!
BlazingPedals is offline
Tags
Bicycle, Road Bike, Mountain Bike, Random Tire Blow Out, Tire Blow Out, Bicycle Maintenance
How do you properly put a tire on? Komodo64 Mountain Biking 3 08-08-2010 10:36 PM
Best road tire for value KC-Steve Tires / Wheels 12 02-05-2010 11:43 PM
Tire Conversion Farnsworth Fixed & Singlespeed 2 12-03-2009 09:36 PM
Tire liners wild Beginners Forum 21 10-06-2009 04:25 PM
Fat Tire Ale Jenjabread General Bike Discussion 18 08-27-2009 08:53 PM
