Bike and Cycling Forum > General Forums > Off Topic > Bicycle Pump Gun
Old 11-19-2009, 03:08 PM   #1
funetical's Avatar
Bicycle Pump Gun
I found this on you tube thought somebody here might appreciate it.
YouTube - Bicycle-Pump Air-Cannon @ 43 PSI
funetical is offline
Old 11-19-2009, 04:12 PM   #2
Administrator
TxCyclist's Avatar
Re: Bicycle Pump Gun
Awesome! I wonder what he's shooting as the projectile.
Unanswered Threads
TxCyclist is offline
Old 11-19-2009, 05:17 PM   #3
Michigander's Avatar
You can make a system like that that has multiple air chambers for multiple shots between recharging. I used to like to press fit the caps on the ends of the PVC barrels. That is by far the most powerful projectile I know of for PVC cannons. Also fun when they hit something and shatter.
It's a cheap, fun hobby. Great for kids. Although I've realized as an adult who has done a lot of construction and demolition just how lucky I was that I never had PVC pipes blow up on me when pressurized. I used to use dry ice sublimation as a means to create pressure. That easily went over 300 PSI. Would have been a lot smarter to have used reinforced copper tubing for that high of pressures.
Michigander is offline
Old 11-20-2009, 02:21 PM   #4
Younger than Hack
Grape Ape's Avatar
Something to think about if you are using these with children who may over pressure them is to use ABS plastic instead of PVC. ABS when it fails doesn't break into many projectiles it usually just splits. PVC breaks apart into many small pieces that can become hazardous.
Grape Ape is offline
Old 11-20-2009, 06:57 PM   #5
funetical's Avatar
I never thought about that. Pvc does shatter into a million dangerous little pieces.
Old 11-20-2009, 09:14 PM   #6
Craziness. I like the idea of using a bicycle pump to build the pressure.
Cyclomatic is offline
Old 11-23-2009, 08:35 PM   #7
funetical's Avatar
Right! I thought the same thing. I've seen compressors used just never a bicycle pump.
Tags
bicycle pump gun
Where to find Solar Powered Bicycle? MrSnake Motorized / Electric 36 01-08-2010 08:15 PM
Organization called "Bicycle Benefits" rustang64 Commuting 6 11-04-2009 01:41 AM
New Pump Xela Tires / Wheels 9 10-09-2009 04:59 PM
A bicycle built for....7? Xela General Bike Discussion 3 08-18-2009 02:10 AM
