Bike and Cycling Forum > Bike Forums > Road Bikes >
Are all canti brakes the same for braking power?
Old 02-15-2013, 11:50 PM   #1
mars_yeldir
mars_yeldir's Avatar
Liked 344 Times on 190 Posts
Likes Given: 266
I have Avid Shorty 4 brakes on the cross bike. That thing won't stop worth a crap. It is ok most of the time, but on these gravel roads around here these brakes are killing my hands. On a 15% bumpy bumpy descent the hands are already heavily pressing into the hoods and when you squeeze the snot out of these brakes it will kill your hands. I have had to stop in mid descent before just to get my hands working right so I could hold on. Are these typical, good, or bad canti brakes? What would be a good set to get if I need stronger ones? Thanks.
mars_yeldir is offline
Old 02-15-2013, 11:55 PM   #2
Industry_Hack
Liked 5353 Times on 2764 Posts
Likes Given: 4763
If they are adjusted correctly and not working, swap your pads. You may just need a softer compound. Salmon Kool-Stop pads are supposed to be the hot ticket.
Old 02-15-2013, 11:56 PM   #3
mars_yeldir
Likes Given: 266
Cool. Should be cheap enough to try out. Thanks!
Old 02-16-2013, 12:09 AM   #4
Industry_Hack
Likes Given: 4763
I've seen multi-compound pads too. No info on them, but look interesting. Some have a rubber squeegee to clean the rim as well, which could help too.
Old 02-21-2013, 12:12 AM   #5
superj
still learning
superj's Avatar
Liked 1841 Times on 1082 Posts
Likes Given: 544
My cantilever brakes and v-brakes stop like disc brakes. I can lock the tires up without squeezing the lever to the grips so yours must need some adjusting or something
https://www.biketexas.org/
And now there is one
Lightening phantom (fast, also)
superj is offline
Old 02-21-2013, 01:18 AM   #6
HillDancer
Bayou Biker
Liked 417 Times on 199 Posts
Likes Given: 8
Originally Posted by mars_yeldir View Post
...won't stop worth a crap...typical, good, or bad canti brakes? What would be a good set to get if I need stronger ones?...
First off are you using road controls or MTB? If using MTB levers with cantis then that's a major flaw. However, poor performance compared to any other type of rim brake is typical of cantilever brakes. Try mini-V brakes, they have much better leverage and will work with road pull levers. Can be had for cheap http://www.universalcycles.com/shopping/product_details.php?id=48336&category=34 up to expensive http://www.paulcomp.com/minimoto.html
If you are using MTB brake levers you will need regular V-brakes.
HillDancer is offline
Old 02-21-2013, 02:04 AM   #7
davereo
davereo's Avatar
Liked 5710 Times on 2714 Posts
Likes Given: 5919
You can also check these brakes out available from Amazon.
http://tinyurl.com/avubz7g
I also copied this note from the review someone posted. I thought it was good information if you do swap.
"Addtional items you need to purchase if moving from a standard canti setup:
10mm spacer (to replace the cable hanger in the headset stack)
Jagwire v-brake noodle w/barrel adjuster"
John Heisman
davereo is offline
Old 02-21-2013, 02:53 AM   #8
mars_yeldir
Likes Given: 266
I have a typical cyclocross setup with SRAM Rival shifters. Avid shorty 4 brakes. LBS said Avid Ultimates or Paul's would be better but to try better pads first like Hack suggested. I also need to practice getting in the drops to get better leverage but on these steep gravel road hills with gravel like marbles that is a challenge.
Old 02-21-2013, 03:09 AM   #9
HillDancer
Bayou Biker
Likes Given: 8
...the hands are already heavily pressing into the hoods ...
Pad compound and my poor opinion of cantilever brakes aside, that symptom alone points to a lever mismatch, or straddle wire too long (for a low profile canti), or both. Your could shorten the straddle wire and see if that provides improved leverage when the lever is near its limit.
Last edited by HillDancer; 02-21-2013 at 03:57 AM. Reason: second quote response removed
Old 02-21-2013, 12:42 PM   #10
kneedrachen
kneedrachen's Avatar
Liked 7500 Times on 3617 Posts
Likes Given: 13755
Knowing Mars like I do, I think he's trying to get someone to say "Well, if you really want to be safe, you should get a new bike" so he has some ammo to approach his CFO with.....
kneedrachen is offline
Proper Braking Method on a Road Bike Weav Beginners Forum 11 10-29-2011 06:43 AM
getting the most power out of my engine murduk0420 Beginners Forum 9 03-17-2010 12:20 PM
Smoothing rim braking surface Xela General Bike Discussion 3 08-18-2009 06:58 AM
Power Meters? cleric Road Bikes 17 08-07-2009 08:39 AM
