Depends on how serious you're going to train. A cheaper trainer like the Performance one won't get to higher watt levels as the more expensive units, but that's ok if you're not going to get real serious on it. Otherwise the top three trainers in the mid price range (between $250 to $399) are Cyclops Fluid 2, 1Up, and Kurt Kinetics Road. I own the Fluid 2 and it's a great unit, had it for 8 years and no problems whatsoever. However, if I were to buy one today I would get the 1Up, it has a much higher wattage work out capability then the others and it's the only one now made in the USA.
If you keep you're eye on Craigslist these things come up all the time for less then half the cost.
