Originally Posted by fleeter
Hey guys!
I just wanted to pick your brains on what you typically upgrade first when you purchase a bike (assuming it doesn't have all the stuff you want in the first place). I know answers are going to be all over the board, but just let me know.
Do you first get a new saddle? or do you have a favorite brand of wheels that you always get? crankset and pedals? What do you upgrade first?
When buying a new bike, most good bike shops will let you swap the saddle and pedals for an up charge (or sometimes even free) depending on what you want to replace them with. Many new bikes do not even come with pedals, so you would have to purchase them at the time you bought the bike. I wouldn't really consider a saddle or pedals an upgrade. You should be starting out with a saddle that fits properly and pedals that you are comfortable with. The exception would be going from flat pedals to clipless, which I highly recommend for most types of riding (road & xc mtn biking).
As already mentioned, wheels are an area that, in most cases, will give you a significant performance increase unless you bought a very high end bike. Good wheels are expensive and most manufacturers spec less than wonderful hoops on their entry to mid-level bikes. Wheels are also very likely the most spendy upgrade that you will make. A high end set of wheels can set you back hundreds or even over one thousand bucks.
I would recommend you just ride your bike. You will figure out for yourself which components you are happy with and which ones not so much. Upgrade through attrition. As thing break, which they will especially if it's a mtn bike, replace them with the best that you can afford. The best doesn't necessarily mean the most expensive.
If you'd like to post up what you are riding, we may be able to tip you off to the weak links. For instance, I have an 02 Giant NRS3. The first upgrade that I would recommend for anyone who owned that bike would be a new crankset. The OE crankset is a boat anchor.
