Originally Posted by wild
Serfas, Seca s surviver series, triple flat protection I think thay were around $45 each
I have picked a lot of glass out of them so far so good.
I use the Sefas Seca from REI, $24 for the wire bead model. About $30 at the LBS for folding. Wife uses GP4000's weighs much less than I do and they are not nearly as cut resistant as the Seras tires.
I just can't see spending $60 on tires that wear and tear so fast.
The Serfas Seca run a bit narrow. IF you use a 700X25, it will be about the same width as the GP4000 700X23.
The Serfas 700X23 is narrow compared to the GP4000 as is the 700X23 Conti Ultra Race ( I also use the 25 in the Ultra Race model).
