Bike and Cycling Forum > Bike Rack > Mountain Biking > Front shock lube
Old 06-05-2009, 01:30 PM   #1
Front shock lube
What do you use to lube or clean th exposed part of your shock? I was going to buy some "oil" from a bike shop, but I was wondering if there is anything around the house or garage that you can use. I am not changing the oil inside the shock or servicing it. I just want to do a little preventative maintenance. I have a Fox Shox BTW.
TheMan is offline
Old 06-06-2009, 05:15 AM   #2
Not familiar with your shock, I ride Rock Shok Sid, I don't belive there is any reason to lube the unprotected part of your shock. I dont think you will prevent anything, but will atract more dust and debris to it.
powderbock is offline
Old 06-06-2009, 06:37 PM   #3
I agree with powder. I use a shop rag to clean the dust of after almost every ride (takes 30 seconds) and do not add anything.
tetonmtnbiker is offline
Old 06-11-2009, 11:50 PM   #4
There is no need to lube the stanchions. The wiper seals take care of keeping em clean when they compress inside the fork legs so just use a rag or something like that and wipe the dirt off. Other than that there is nothing else to do.
tajcrews is offline
Old 06-18-2009, 09:09 PM   #5
Neuner's Avatar
Yours is Fox but I'm familiar with Rock Shox which has a 'special lube' priced high for what it is called Judy Butter. It's really just simple axle and bearing grease. If your shock uses air or springs then it should be the viscosity that may affect the ride but never damage the parts. I still have Englund Air inserts in my Judy and as a friend, who is an avid rider/racer recommended, I use Axle grease to lube the stanchions internally and a bit of motor oil to slow down the rebound slightly. Has been working perfectly for about 4-5 years now.
Neuner is offline
Chain lube wild General Bike Discussion 30 10-21-2009 01:59 AM
Fox Shock PSI Bradford Mountain Biking 6 10-20-2009 12:32 PM
Lube it or lose it Industry_Hack General Bike Discussion 3 10-13-2009 03:01 PM
Scwinn Impact Front Shock guyonabike Road Bikes 0 08-04-2009 09:44 PM
Need new front shock FOXshox Mountain Biking 10 06-11-2009 11:41 PM
