Originally Posted by tajcrews
It does use a powerspline BB
The Isoflow came with both a square taper or the powerspline bb interface. If it is a powerspline, it's very likely that the splines on the crankarm were damaged when the arm became loose on the bottom bracket. If that's the case, it may be repaired with a small file. Otherwise, replacement is the only fix.
