Bike and Cycling Forum > Bike Rack > Mountain Biking > Hydraulic Brakes
Old 07-30-2009, 08:48 PM   #1
Hydraulic Brakes
I have 2007 Hayes Nines and the pads are a little worn down, but I want to get their full life out of them but I cant one-finger brake anymore because the lever comes in too far. How can I adjust the brakes so that when the brakes grab, the lever isn't being pulled all the way into my fingers?
So help me, Jebus....
hewlett is offline
Old 09-07-2009, 11:44 PM   #2
Theres a very small allen bolt where the lever attatches to the housing. You can see it looking down the handle bars end to end. Adjust that to your liking.
coiler05 is offline
Old 10-19-2009, 09:42 PM   #3
hardtail hardass
ruggedscotsman's Avatar
x2 on the adjuster screw behind the lever. If that doesn't solve the problem, have them bled and the shop can set the limit then. There isn't enough thickness in the break pads to make a noticable difference in how much you can pull the levers.
ruggedscotsman is offline
Old 10-31-2009, 03:30 AM   #4
I dominate Downhill
yeah, hydraulic are hard to work on if you dont have to much expertise, a shop or good bike freind would work best
topgun514 is offline
No Brakes? radracer BMX / Trials 22 06-28-2011 08:35 PM
Rim brakes cbman Mountain Biking 8 01-09-2010 12:55 AM
Mech Dual Control to Hydraulic? Heartless General Bike Discussion 2 08-29-2009 08:26 PM
