Bike and Cycling Forum > Bike Rack > Mountain Biking > Need new front shock
Old 06-06-2009, 09:50 PM   #1
I have a specialized hardrock sport mountain bike, and the left fork seal blew up. I've had the bike for awhile and the forks are old anyway, I was planning on replacing them. So what are some good budget shocks that will fit? I dont know much about mountain bike aftermarket parts so links would help, thanks!
FOXshox is offline
Old 06-07-2009, 02:33 AM   #2
i found my marzocchi dirt jumper 3's on ebay and got them for $120 shipped. they are from 2005, but they were unused. check out ebay, find a bunch of shocks that fit your budget and you like. then go to google and search reviews for each shock. thats what i did, and it helped narrow down which ones i wanted. usually reviews on google where at mtbr.com.
good luck
Don't call me a farmboy, call me a redneck.
bootht99 is offline
Old 06-07-2009, 02:59 AM   #3
you probably won't want a fork with more than 130mm, more than that will eventually break the frame, so keep that in mind. Also, just personal preference, you will probably want more than 100mm, it's more fun that way. some forks will be cheaper, but you pay for it in weight. If you do xc/all mountain rides, or pedal your bike at all, you probably want to keep them sub 5lbs. just my two cents
Dstompe is offline
Old 06-07-2009, 03:30 PM   #4
what do you mean keep them sub 5lbs? I ride my bike around town a lot doing curb jumps a lot too. When I can I prefer to find the bigger dirt jumps. I broke them on a dirt jump. I might have the manual around I can check the stock settings and go from there. I kinda liked the stock forks, but they could have been a little stiffer.
And thanks for the help guys!
FOXshox is offline
Old 06-07-2009, 03:41 PM   #5
Doc
Doc's Avatar
I think he means sub 5lbs of total weight to reduce the weight of your bike.
Doc is offline
Old 06-07-2009, 07:26 PM   #6
oh ok. The bike is pretty heavy to begin with.
FOXshox is offline
Old 06-08-2009, 06:04 AM   #7
what size of headset do you have? (i think thats what its called) 1 7/8" i'm guessing? that will help narrow it down a bit.
yeah, sub means under. submarine=underwater. my dirt jumper's are pretty heavy, but i love them. they are adjustable between 100-130mm of travel. it has only been the last week or two that i have been really using them, doing lots of drops (about 4ft onto grass and pavement) and lots of jumps. (i set up a jump, then jumped off the highway into my ditch. thats a long distance). they haven't bottomed out yet. they are currently set at 115mm, they are a bit soft for lots of flatland riding, but that just made me ride more leaning back taking the pressure off my forks so they don't bounce up and down.
bootht99 is offline
Old 06-08-2009, 02:39 PM   #8
I guarantee he has a 1 1/8 headset, it's pretty standard for all but newer big downhill and all mountain bikes that run 1.5 headsets. Since you are not worried about weight and are worried about price then go with the something like these
http://www.pricepoint.com/detail/18381-315_MARD29-3-Parts-59-Forks/Accessories/Marzocchi-Dirt-Jumper-2-2009.htm
http://www.pricepoint.com/detail/18372-315_MAR229-3-Parts-59-Forks/Accessories/Marzocchi-22-R-2009.htm
http://www.pricepoint.com/detail/18373-315_MAR339-3-Parts-59-Forks/Accessories/Marzocchi-33-TST2-2009.htm
http://www.pricepoint.com/detail/18556-315_ROCT39_KIT-3-Parts-59-Forks/Accessories/Rockshox-Tora-302-Coil-2009.htm
Dstompe is offline
Old 06-09-2009, 03:10 PM   #9
Neuner's Avatar
I was going to suggest replacing your shock cartridges and seals with a Total Air Englund Cartridge but it appears they've stopped making them. I'm ticked. I love mine and don't want to have to face if I ever blow one out.
Neuner is offline
Old 06-10-2009, 04:54 AM   #10
How old is your bike? If its like my old Rockhopper comp (1991), you may find it a little difficult to find a shock that won't change your geometry. Best bet would be to take it into your LBS and get their opinion if its an older model bike.
I placed a front shock on the rockhopper in 2000, eventually bent out the head tube causeing the LBS to put a shim in it.
powderbock is offline
Shock & Awe! (Awesome Cable-Cam video!) unigeezer Mountain Biking 4 03-16-2010 12:09 PM
Fox Shock PSI Bradford Mountain Biking 6 10-20-2009 12:32 PM
Seat Post Shock stranger_01 General Bike Discussion 4 08-07-2009 02:32 PM
Scwinn Impact Front Shock guyonabike Road Bikes 0 08-04-2009 09:44 PM
Front shock lube TheMan Mountain Biking 4 06-18-2009 09:09 PM
