Bike and Cycling Forum > Bike Rack > Mountain Biking > SRAM derailleur Disassemble Fail
Old 09-25-2011, 08:04 PM   #1
I am trying to take an SRAM back derailleur off of a mountain bike to put on my road bike, the derailleur is a drop frame fixture (I think that's the terminology), meaning that it doesn't screw on next to the frame where the wheel is placed but underneath it by less than an inch, we've all seen them.
The problem is I cannot figure out how to get the chain off of the derailleur, I do not have the tool to pinch out a gap in the chain, I'd rather take off one of the pulleys. I have included pictures to illustrate why I cannot figure out how to get the pulleys off. What type of driver or wrench do I use?
Thank you.
Looking at the derailleur from the front.
Back side position #1.
Back side position #2.
Eusebio is offline
Old 09-25-2011, 08:38 PM   #2
Likes Given: 2
That looks like it's pressed or riveted in. Disposable parts, not for reuse.
Old 09-25-2011, 10:37 PM   #3
Vendor
PlatyPius's Avatar
Yep. Not removable.
And that chain is toast.
Got Coffee? Get some great coffee sold by a cyclist for cyclists. Amazing! Coffee that doesn't taste like gasoline! http://www.rapidoroast.com
Disclaimer: I own a bike shop. Yes, I'm biased and opinionated.
PlatyPius is offline
Old 09-26-2011, 03:09 AM   #4
Darnit, I really don't want to buy a Mini Chain Brute Chain Tool or anything.
Eusebio is offline
Old 09-26-2011, 07:22 PM   #5
get a new one.... that model is on e-bay for around $14.00
ibisman is offline
Old 09-27-2011, 01:31 AM   #6
The chain is no good anyway. Get the tool and a new chain if the budget is tight. I would probably just get a new rear derailleur as well. Probably have fewer issues long term to put a road bike derailleur on a road bike
photosbymark is offline
Old 09-27-2011, 02:00 AM   #7
TwoJ
rola643's Avatar
Liked 5 Times on 5 Posts
Likes Given: 7
Wuz wrong wit dat chain?
I spent half of my life riding bikes. The other half I wasted.
rola643 is offline
Old 11-01-2011, 04:09 PM   #8
hardtail hardass
ruggedscotsman's Avatar
Buy a chain tool, and replace your chain more often cause that one is toast.
they're like 10-15$
ruggedscotsman is offline
Old 11-03-2011, 12:53 AM   #9
Fellas, I'm asking about the derailleur assembly, obviously the chain is toast.
Question is answered, close thread.
Eusebio is offline
Old 11-04-2011, 08:53 PM   #10
I think what you missed is that derailleur wasn't meant to be taken apart to put another chain through. The chain was broken into and threaded through the derailleur and then the link put back together. That derailleur has seen better days anyway, so I would recommend replacing it as well. Some lower end versions are less than $20 and Forte makes one that I think I paid less than $40 that is a bit more robust. You probably would be better off to get a new derailleur as well, but that's up to you. Either way you are going to need a chain tool to break the chain to feed it through. While you are at it, look at the cage of your front derailleur and you are likely to find that the chain runs through a metal box that has no way to disassemble. That bar that keeps the chain from dropping too far is most often cast, welded, stamped or otherwise made as to keep any part of that derailleur from being removed to allow the chain to pass through. You either have to break the chain or cut the derailleur.
Big Hill/Big Fail! Hazy Training / Health 17 05-17-2011 03:11 AM
Need a new derailleur for a 21 spd. glazer1972 Mountain Biking 1 12-15-2010 03:49 PM
Fail!!! bikebum1975 Off Topic 7 11-12-2010 02:45 PM
Sram x7 rear derailleur Grape Ape Mountain Biking 3 11-08-2010 07:57 PM
EPIC Fail - Some people just don't get it... djcyberlegend Off Topic 10 01-18-2010 08:44 PM
