Bike and Cycling Forum > Bike Rack > Mountain Biking > what size cage?
Old 11-30-2009, 04:21 PM   #1
what size cage?
In the market for a new rear derailer. Not really sure what size cage to get. Short, med or long? What are the advantages to each? I'll be putting this on a kona coiler if that helps.
coiler05 is offline
Old 11-30-2009, 09:16 PM   #2
Younger than Hack
Grape Ape's Avatar
The best way to figure it is by adding the difference of your large and small chain ring along with your large and small cog.
So based on my Cannondale with Shimano components the front chainring is 22/32/44 and the rear cogs are 11-32. Figured up I would need a rear derailleur capacity of (44-22) + (32-11) = 22+21 = 43t. Based on that you can check the manufacturers literature on the derailleur and see what they advise.
From Shimano's website their medium cages are 33t the large cages are 45 t. Sram says 43t is long, 37t is medium and short if 30t the numbers are based on total capacity from the above formula. They also have some that have a max difference on the rear cog and max difference between chainrings. So check, because if you buy based on max capacity, it may have limitations in what that max capacity can do. Due to chainring sizes.
Grape Ape is offline
Old 12-01-2009, 02:23 PM   #3
Drink plenty of water!!!
chh55's Avatar
Talking Road bikes here...basicly a short cage is for 2 rings, either normal size (53-39) or compact (50-34)up front and a "normal" size cassette, in other words 27 or 28 tooth max in back.
The long cages are for 3 rings up front, touring or MTB set ups.
The compact idea is quite a good one. It gives you a real climbing advantage while staying with a standard 2 chainring set up. They are very popular nowadays... for good reason. The compromise is a somewhat smaller top gear which in all honesty... how often are you pushing 53-11 anyway??
chh55 is offline
Old 12-01-2009, 08:55 PM   #4
Its going to be going on a 22/32/bash crank. Not sure of the cassette yet. I'm going to be re-doing the whole drivetrain.
coiler05 is offline
Old 12-01-2009, 10:46 PM   #5
A Red Headed Stepchild
Mootsguy's Avatar
On three of my bikes I run that same chainring set up with 8/9 speed 11-34 cassettes with an Ultegra short cage derailleur. Works great and the derailleur is up and out of the way of rocks and such.
“I recommend bread, meat, vegetables, and beer.” – Sophocles
Dopers suck!
Mootsguy is offline
Old 12-02-2009, 07:52 AM   #6
chh55's Avatar
Hey Moots, I did not know that a short cage would do a 34... news to me!
chh55 is offline
Old 12-02-2009, 04:56 PM   #7
Mootsguy's Avatar
chh, here is a look at my use of a short cage DuraAce with a 12/34 8 speed cassette.
Dopers suck!
Mootsguy is offline
tire size London Off Topic 2 12-02-2009 03:04 PM
Proper frame size -- ?? G6612 Road Bikes 7 09-19-2009 04:08 PM
Crank Size KFaulkner General Bike Discussion 11 09-02-2009 03:49 PM
Panasonic BB size Cruso Road Bikes 0 05-28-2009 04:12 PM
