Bike and Cycling Forum > Bike Rack > Mountain Biking > What Tubes
Old 08-28-2009, 04:48 PM   #1
Administrator
TxCyclist's Avatar
What Tubes
Lately I've been going through tubes like crazy. Drought has been causing these large sticker plants to sprout like crazy. I need to drop the cash and upgrade to more high end ones.
What tubes are you all running?
Unanswered Threads
TxCyclist is offline
Old 08-28-2009, 06:00 PM   #2
Sounds like you need to get Slime tubes. Specialized makes a version as well. Or, if you have schrader valves you can buy a bottle of slime and do it yourself. Unable to do it yourself with presta valves.
You need to get a better tire (kevlar beaded) if you don't already.
Also there are plastic inserts (Tuffie I think the name is) you can place in between your tire and tube to help prevent puntures.
I ride in an area with lots of thorns, I just use Slime Tubes and Kevlar tires. Slime adds some weight, but it worht it.
powderbock is offline
Old 08-29-2009, 12:21 AM   #3
DX's Biggest Member
CTD50's Avatar
Tubes are less the issue here than the tires you're running -- at LEAST, run some sort of SpinSkins kind of liner between your tire & tube, but a better solution is a heavier-duty tire.
CTD50 is offline
Old 09-14-2009, 09:22 PM   #4
Biker's Avatar
Do slimed tires have the same feel of normal tires?
Biker is offline
Tubes: Patch or Replace? HandsomeRyan General Bike Discussion 29 06-06-2010 11:00 PM
Pros & Cons of OS Tubes? MFG_bike Road Bikes 3 10-20-2009 06:36 PM
Tire Tubes bakers General Bike Discussion 6 08-14-2009 08:50 PM
Off Road Tubes? JamieDamnGarrett Tires / Wheels 9 07-28-2009 05:21 AM
