Bike and Cycling Forum > Bike Rack > Mountain Biking > When do you replace bike brake pads?
Old 01-16-2010, 04:56 PM   #1
gnar! gnar! gnar!
cbman's Avatar
I'm putting up some pictures of both my front and rear pads. I'm wondering if it's time to replace them. They seem pretty worn and the rear brakes won't lock up any more. The pad on the left is the rear one, the one one the right is the front. Also, should I replace the disk the same time as the pads?
Let us see...
what bike part shall we order this week?:rolleyes:
cbman is offline
Old 01-16-2010, 08:55 PM   #2
Liked 2 Times on 2 Posts
They all appear to have plenty of life left, but the fronts look glazed. You might want to try to knock the glaze off with some fine sandpaper. Most likely, the rotors are fine.
hophead is online now
Old 01-16-2010, 11:07 PM   #3
DX's Biggest Member
CTD50's Avatar
Unless you have grooves in the rotors that almost gouge your fingernails, they should be good.
One indication of "needing pads" is, indeed, the loss of power; however, roughing them up CAN give you some more life, as it looks like you have pad material to work with. But if the roughing doesn't work, it's time for new....
...And I always recommend ceramic pads! Two years of awesome performance in my BB7's! Modulation is a step above ANYthing else I've used, and the stopping power is there all day long.
SEZ THE KONA: "AH'M DEAD SEXAY!"
CTD50 is offline
Old 01-17-2010, 01:07 AM   #4
gnar! gnar! gnar!
cbman's Avatar
thanks guys!
Let us see...
cbman is offline
Old 01-17-2010, 02:29 AM   #5
Likes Given: 2
My custom titanium discs were like sandpaper to the pads, and they ripped through them in less than 200 miles. The front pads seized and gouged the rotors. That was an expensive ($300) lesson that I don't care to repeat.
Break the glaze with some fine grit paper, keep your oily fingers off the braking surface, and you'll be fine for some more miles.
Old 04-02-2010, 06:21 AM   #6
BB7s are the poo... who needs hydro when they work that well!
Jake_The_Snake is offline
Tags
pads, brakes, bike brakes, discs, mechanic
Tubes: Patch or Replace? HandsomeRyan General Bike Discussion 29 06-06-2010 11:00 PM
How do I run brake housing with aero brake levers, the cable runs from underneath?? fujiyama General Bike Discussion 0 05-30-2010 04:21 PM
When to replace tires? tydale Road Bikes 13 10-24-2009 05:49 PM
Replace shifter or derailer? Alexia General Bike Discussion 4 07-21-2009 09:09 PM
Brake Pads bb-dan General Bike Discussion 2 06-12-2009 12:32 AM
