Bike and Cycling Forum > Bike Rack > BMX / Trials > Brake Questions
Old 07-07-2009, 09:54 PM   #1
Brake Questions
Odyssee Evolver brake mounted to the bottom of the seatstay. Stock 1BY4 pads. RBJ1 Steel rim. Pads are making square contact to the rim. But the thing won't stop the bike at all. The chromed steel rims are like glass. Would a different pad bail us out? Or can these pads be altered?
Bradford is offline   Reply With Quote
Old 07-08-2009, 01:24 AM   #2
Brian P's Avatar
make sure the rims are clean first.... spray nine or glass cleaner will work wonders
Brian P is offline   Reply With Quote
Old 07-08-2009, 01:50 AM   #3
different pads can help but might not be the perfect solution.
tajcrews is offline   Reply With Quote
Old 07-08-2009, 08:35 PM   #4
The brakes could be adjusted all the way against the rim but the tension in the brake lines can be too slack to apply enough pressure... just a thought Turn the knobs on the levers to tighten the wire, put some sticky grip stuff on the brake pad like a car does
water is offline   Reply With Quote
Old 07-22-2009, 08:55 PM   #5
you need to adjust ur brakes and a good chrome rim will stop you good, dont spray ur rim with windex or a cleaning supply like stated makes ur brakes loud as hell, and wont stop you right, just wipe them with a cloth
Shadowrider19 is offline   Reply With Quote
Old 07-28-2009, 05:41 AM   #6
pedal pusher
vassago's Avatar
steel rim? seriously?
vassago is offline   Reply With Quote
Old 01-02-2010, 10:19 PM   #7
Try this
No. Evolvers if put on correctly should stop perfectly with stock pads. They are the best breaks ever made they should have enough torque to grab that rim, but you are right that some rims do slide through the pads. So try this ride it a lot so rubber accumulates on the rim also take the pads off first and rub them across the sidewalk making them course. If that does not work find some that are more soft and gummy. Just get that rim coated with rubber.
oldshoolelf is offline   Reply With Quote
Brake upgrade wv-mtneer Mountain Biking 1 12-01-2009 07:55 PM
Training Questions. justintime Training / Health 2 10-16-2009 07:31 PM
Bike maintenance questions Xela General Bike Discussion 10 10-07-2009 01:14 PM
Plz need help on some questions????? BIGPBS General Bike Discussion 8 10-05-2009 03:58 AM
Brake Pads bb-dan Bicycle Mechanics Forum 2 06-12-2009 01:32 AM
  • rss
  • facebook
  • twitter
