02-21-2011, 01:12 PM
Batteries vs Cold
All forms of batteries seemed to be adversely affected by Cold!
Very noticeable, especially on my various ebikes, was that, cold greatly reduced the rate of output, as well as the capacity of various types of batteries.
This degradation is common to both Li-ion, as well as SLA batteries. Based on complaints, from others, LiFePO4, Li-po, Nimh etc. seem to suffer similarly.
The "rate of output" is often designated as the "C" rating. For example a 30ah battery, capable of a 30 amp output, would have a rating of 1C, a high performance RC car battery, (Li-po), might be a 5ah 20C rated, thus capable of a 100amp output, of course it would empty, very quickly!
Sub freezing temperature might cut the C rating, as well as the overall capacity by 50%. 0 degrees Fahrenheit degrades considerably more!
In my experience, most of this degradation is due to the battery temperature, though the cold motor and drivetrain also contribute, somewhat.
My recommendation is that the battery should be kept warm.
Easiest would be the use of a water heater blanket, to maintain ambient heat.
Rambo mode! -I- January 15, 2012 - January 19, 2012 RIP
"To survive war, you must become war."
When I go ... I wanna go to eBike heaven
02-21-2011, 01:34 PM
Why do you hate the environment?
02-21-2011, 02:13 PM
Eco terrorist ... not!
How do I "Hate the environment"?
Because I prefer electric vehicles over gasoline?
Because I recycle used notebook batteries into electric bicycle batteries?
Because I prefer Li-ion, the environmentally safest and most profitable to recycle, type of battery?
Because I advocate extending battery efficiency and use into the colder environs?
02-21-2011, 02:30 PM
That was a joke. I just think it's silly that someone would go to the trouble of trying to keep their batteries warm. Just ride.
02-21-2011, 03:40 PM
Battery Improvements!
How could you possibly think it is a joke, to claim a person hates the environment, because he is trying to make batteries more efficient?
02-23-2011, 08:30 PM
eVehicle technology!
Batteries, being warm, increases your range by between, possibly, 50 and 100%+.
Most noticeable is if I leave my bike, or battery outside, while at work.
Partial solution is that I carry my Li-ion homemade packs in one of those insulated-waterproof lunch bags. I just unplug, and carry inside with me, (25.9v 31.2ah weighs about 9lb.) Typical non-pedal range is between 20-40miles per charge. Pedal assist range varies by speed, 16mph 100++ miles, 20mph possibly 50miles+. Full charge top speed is 22mph+, (on this modded bike.)
Actually the severest complaint about electric cars is how drastically their range is reduced by cold weather. On eCar forums, I've recommended, insulating the batteries, combined with the use of the common, water pipe, thermostatically controlled heat tape. Which would keep batteries warm during charging, pointing out, that a battery powered 100w heat tape could keep the battery warm, sitting outside for a full, cold, workday, using only 2% battery capacity while increasing usable battery output by, possibly, 100%.
At this time, I view eBikes as testbeds, or prototypes, for the technology that could be employed in larger eVehicles. I soon will be producing eTrike conversions as "mobility devices" for handicapped, or old persons, hopefully bypassing NY State anti-eBike stance. (Using the Schwinn Meridian, hanging heavy SLA batteries below the rear basket should increase stability substantially and leave room for groceries etc.) Hybridization will be possible! I have a 53lb 1500w 4-cycle generator capable of supplying 600watts for 12 hours on 1.5gal gas. Just drop the generator into the rear basket, plug-in and "long-haul" it. (1200w continuous should motivate at well past 30mph)
This will be my Stage 2, eBikes being my Stage 1.
Prototype should be ready by Spring.
Some people might be concerned by my use of "possibly", "probably", "likely". I have a "scientific" mind, absolutes like, positive, absolute, need, rarely exist, else we might still be living on a flat Earth.
I view "certainty" to be a crutch for the narrow minded!
Hmmm .. Maybe ... it's just my ex-wife, constantly yelling, "And that's just all there is to it!", in my ear ...
02-24-2011, 12:15 AM
TwoJ
Liked 5 Times on 5 Posts Likes Given: 8
Hack.....go to your room....close the door and don't come out until we tell ya to! AND leave your puter out here with us. No innanets for you.
I spent half of my life riding bikes. The other half I wasted.
02-24-2011, 02:54 AM
Mind if I fix myself a drink first?
02-27-2011, 05:19 AM
Simple test.
Just performed a basic comparison between 18650 Li-ion at 30* and 60*. Using the same 380 lumen LED flashlight, 30* output was 1.2 amp, 60* output was 1.4 amp. That is almost a 20% reduction caused by a 30* differential.
Test was conducted using 2 batteries that tested the same output at room temperature, then one was set outside for an hour to chill.
Would have tested a wider range but was too warm today, and no freezer at work.
* = degree Fahrenheit (closest keyboard option)
01-01-2012, 01:39 PM
#10
Battery Pack Warmers!
Everyne knows that cold degrades your batteries performance.
Solutions?
Insulate your pack.
For Li-ion, LiPo, LiFePO4 etc, insulated lunch bags, 6pack coolers etc, provide nice thermal protection.
Pre-warm your pack.
or ... add heat packs, gelled preferred, liquid might not be recommended!
Keep your battery packs warm.
Low wattage pads, in conjunction with insulation, should perk up your batteries, cold weather performance!
Found a nifty little item that might be the best-cheapest solution!
All Sold> 12v Flexible Adhesive Heatpads $5.39/pair
New Link> 12v Flexible Adhesive Heatpads $5.39/pair
Another Link> 12v Flexible Adhesive Heatpads $5.39/pair
Another Nother Link> 12v Flexible Adhesive Heatpads $5.39/pair
Inexpensive, thin, flexible, self adhesive, low wattage heating pads.
Low wattage ... add as many as necessary!
Will run preliminary tests with separate power source, 3S Li-ion. To measure drain & performance increase.
Note: Should run nicely at 2S, or 1S, for less heat output! 4S, for more?
Ordered a few pairs, from China ...
But might take a couple weeks ... will post review, as soon as possible.
I would like to apologize, to the "decent" members of the forum.
Recently the unchecked bullying, on the forum has upset me to the point that I will no longer sit back and take it.
So I have become pro-active in the effort to attract attention to the problem.
My step #1 was to make sure the Mod was aware.
Step #2 was to point out that such activity, made the entire forum, a place where decent members ... would rather not be.
Step #3 since bullying seems to be the accepted behavior, I have engaged in a bullying campaign, against the bullies! Just demeaning their intellect, lack of reasoning etc.
Sadly, (I almost feel sorry for them), when pressed, they tend to shrivel up, and fall back on their infantile vulgarities.
Which does seem to attract enough attention, to get them censored, warned, or banned!
A simple show of support, would be to click on the "report" button of any post, that you deem "objectionable", and of the type, you don't believe should be allowed on this forum..
Feel free to quote this "notice".
