Building A Motor Spreadsheet
Data starts on row 8:
Column A : Rpm : From 0 to 3700 I spaced 100 per row
Column B : Voltage : MIN(((C8)+(SQRT(C8^2+4*($Voltage)*($Current*$Resis tance))))/(2*$Voltage),1)*$Voltage-C8
Column C : BackEMF : A8/$Kv
Column D : Current : B8/$Resistance
Column E : Heat : (D8*D8)*$Resistance
Column F : Power(In) : (B8+C8)*D8
Column G : Power(Out) : ((B8+C8)-(D8*$Resistance))*(D8-$NoLoad)
Column H : Efficiency : G8/F8
Constants are:
$NoLoad : 2.25
$Resistance : 0.337
$Voltage : 48
$Kv : 78
$Current : 40
...if you create a spreadsheet with these formulas you can then plot the graph yourself:
