Bike and Cycling Forum > Bike Rack > Motorized / Electric > tunning up bike not enough power?
Old 03-16-2010, 09:07 PM   #1
I have a 78' murray montery with an 80 cc engine from ebay that I just finished putting together but it's not producing enough power like it's holding back some how. I have the throttle pin set at the last ending closest to dish for a rich mix any hints or advice to not be so slow would be apreciated.
murduk0420 is offline
Old 03-17-2010, 12:11 AM   #2
retromike3
too rich ?
If your putting to much gas in you might be flooding it.
after you set it back to stock I would check the seal around the carb for leaks and then make sure the head bolts are on tight enough (12 pounds per inch)
Next check the gap in the spark plug (I think it was 024) Also check to see if you have a good spark(take out the spark plug put the wire back on, lay it on the head let out the clutch and give the pedal a spin, if you have spark then your OK there.
Finally what is your mixture? check the specks and see if you have too much oil in your gas.
Mike Frye the bike guy
retromike3 is offline
Old 03-17-2010, 12:16 AM   #3
retromike3
one more thing
is your carb being choked? usually up choke and down is off.
If your engine is choked you wont get enough power.
Mike the bike guy
Old 03-17-2010, 09:49 AM   #4
craisin's Avatar
Well with these 2 strokes the whole crankcase should be considered as part of the induction system. And often if the bike is dropped and the crankcase hits the road it can cause induction system leaks.
I am not saying that is the problem just it can be a problem with 2 strokes.
As Mike suggests you may be running it too rich
Go for a ride on the bike and turn the gas off while you are running it down the road if the engine picks up and runs better before it runs the carb dry indicates it running rich
craisin is offline
Old 03-17-2010, 11:39 AM   #5
retromike3
check the spark plug
Next thing to do would be to check the spark plug. If or when you take it off look at the front of the plug. it should be light tan color, if its black and suety its got to much gas. check the board I am sure that there are pictures of good and bad plugs.
Old 03-17-2010, 09:51 PM   #6
ok, let's say I'm running a 25 to 1 gas to oil ratio and I have the throttle clip set on the end of the pin for a rich mix would that deminish the performance or lack of power issue.
Old 03-18-2010, 02:16 AM   #7
craisin's Avatar
have a look at the plug like mike says or go for a ride and turn off the gas
craisin is offline
Old 03-18-2010, 02:20 AM   #8
Likes Given: 2
I noticed my Harley cutting out today around 80MPH, but that was just the rev-limiter kicking in in 4th gear...
Industry_Hack is online now
Old 03-18-2010, 11:02 AM   #9
craisin's Avatar
hey Hack should go faster than that surely
the rear cylinder has a tendency to run hot on those and the studs that hold the head and barrel to the crankcase are inclined to stretch on the exhaust side of the rear cylinder and can blow the gasket
Im not a Harley fan but friends get addvice off me and Ive encountered 2 with blown rear head gaskets
craisin is offline
Old 03-18-2010, 11:26 AM   #10
Likes Given: 2
Craisin, the solution was to shift into 5th. I've downshifted to pass traffic and hit the rev-limiter a few times. It goes like this "WAAHHHHHHHHHHHHHHHHHHHHHH" to [silence].
Power Tool Build sausagetree Motorized / Electric 10 03-26-2012 04:25 AM
getting the most power out of my engine murduk0420 Beginners Forum 9 03-17-2010 11:20 AM
Human Power Challenge 2010!!!! pcrx Recumbent 0 03-03-2010 12:03 AM
Power Bar Performance Energy Bars Don Training / Health 0 10-27-2009 07:33 PM
Power Meters? cleric Road Bikes 17 08-07-2009 07:39 AM
