Bike and Cycling Forum > Bike Rack > Fixed & Singlespeed > Disk breaks
Old 02-10-2013, 04:30 AM   #1
erk
erk's Avatar
Liked 25 Times on 14 Posts
Disk breaks
I saw a news story about disk breaks coming to the road bikes. I ride a SS and I do use both breaks. I would think disk breaks would be good. I am 240lb and can ride 30- 40 miles an hour and I need some stopping power.
Do ant if you guys have a fixes or SS with disk breaks. Or what do you guys think of the new trend.?
erk is offline
Old 02-10-2013, 04:44 AM   #2
Liked 1981 Times on 1308 Posts
Likes Given: 2200
I don't even know where to start.
[edit] What gear ratio are you running?
Industry_Hack is online now
Old 02-10-2013, 10:30 AM   #3
Merlincustom's Avatar
Liked 338 Times on 202 Posts
Likes Given: 142
I think disc brakes for road bikes are a solution in search of a problem.
Merlincustom is online now
Old 02-10-2013, 02:48 PM   #4
Likes Given: 2200
That's because you don't ride 30-40 miles an hour.
Merlincustom Likes This
Old 02-10-2013, 02:56 PM   #5
Senile Member
carlharsch's Avatar
Liked 613 Times on 312 Posts
Likes Given: 248
dems da brakes
carlharsch is online now
offrdmania Likes This
Old 02-10-2013, 03:01 PM   #6
Buffalo-jon's Avatar
Liked 459 Times on 237 Posts
Likes Given: 701
I'm hoping that's downhill, or I need new Legs. (put that disc brake in front and hit it hard at 40 MPH going down hill and let's see what happens, don't forget to film it!)
The trouble with normal is it always gets worse
Buffalo-jon is offline
Old 02-10-2013, 03:25 PM   #7
Frickle Frack
offrdmania's Avatar
Liked 64 Times on 46 Posts
Likes Given: 40
30-40 mph? How big is the chainring on that singlespeed?
Take the pain, feel the burn. Single speed riding.
offrdmania is offline
Industry_Hack Likes This
Old 02-10-2013, 04:39 PM   #8
Likes Given: 142
You can coast downhill on a single. A 50/13 at 130 rpm is 39 mph.
Old 02-10-2013, 05:23 PM   #9
Frickle Frack
offrdmania's Avatar
Likes Given: 40
It is possible I assume
Old 02-10-2013, 06:44 PM   #10
Trailer Trash
Liked 85 Times on 42 Posts
Likes Given: 3
My disc brake equipped road bike is multi-speed. I often exceed 40mph on descents where the number of gears available wouldn't matter. I also ride on flat lands where even vintage rim brakes with ancient/hardened pads are adequate, so I understand the incredulity expressed by some toward disc brakes. In order for disc brakes to perform better than rim brakes, rotor size and pad compound need to be optimized for the application. There is more friction available on pavement than dirt; don't get the wrong idea from discs intended for cyclocross bikes. For your weight and speeds I suggest a minimum 180mm front disc (bigger is better) and be sure it has plenty of mass to handle heat. Wispy spidery rotors look neat, but don't perform as well as stout hunks of metal.
The bottom line is disc brakes are good, just as you imagined.
HillDancer is offline
Hydraulic Disk Brakes on a Road Bike rola643 Industry News 7 04-25-2012 11:55 PM
What are the best style of breaks for downhill bicycle racing? Terri General Bike Discussion 2 11-12-2009 08:20 PM
Crash breaks bike Xela BMX / Trials 5 09-14-2009 09:48 PM
