Bike and Cycling Forum > Bike Rack > Fixed & Singlespeed > Gearing
Old 02-02-2013, 08:51 PM   #1
Gearing
So..I just finished building up a Cannondale 1fg that I got. I replaced the chainring from a 32 to a 36 thinking it would make me a little faster....I was wrong. Currently I'm running 36/17 and its topping out at 13-14mph. Just wondering what everyone is running on the road. I would like to go a little faster than that. I think right now it is set up good for mountain trail riding. Thoughts?
Avid cyclist from the baltimore area...check out our up and coming website at...
sandscycleworks.com
Sandscycle is offline
Old 02-02-2013, 10:30 PM   #2
Frickle Frack
offrdmania's Avatar
Liked 64 Times on 46 Posts
Likes Given: 40
What BCD chainring are you running? On my old 104 BCD I was running a 32/14 for trail riding but now with my 130 BCD im running 39/17 since 39T is the smallest chainring for a 130. Both are the same ratio. I commute so I look for an easy ride instead of speed. There are ratio calculators online to help you find your right ratio depending on what you are looking for.
Take the pain, feel the burn. Single speed riding.
offrdmania is offline
Old 02-02-2013, 10:51 PM   #3
Merlincustom's Avatar
Liked 338 Times on 202 Posts
Likes Given: 142
Plug in your numbers:
http://www.bikecalc.com/speed_at_cadence
for fixed on the road depending on season and elevation I run 49/19, 18, or 16.
Merlincustom is offline
Old 02-04-2013, 04:04 AM   #4
Sweet link....was pretty close to what I noticed on the bike. FYI I run a 104 bcd. It's a gossamer v drive crankset
sandscycleworks.com
Old 02-04-2013, 04:06 PM   #5
NateInAZ's Avatar
Liked 15 Times on 6 Posts
Typically for commuting I run 42/15. Both of the cranksets I use on my single speeds are 144 BCD. I run Suginos from the 80s and a Miche crankset. For faster rides ill usually run my bike 49/15 or 49/16. I did a single speed tour and ran 42/18. It all depends on what you're doing the most. I'd say to try to start out around 70-75 gear inches for beginners.
NateInAZ is offline
Old 02-11-2013, 03:03 AM   #6
erk
erk's Avatar
Liked 25 Times on 14 Posts
I run a 48/16. On flat I do 15- 20 easly.
erk is offline
Old 02-11-2013, 03:42 AM   #7
Liked 1981 Times on 1308 Posts
Likes Given: 2200
Mashing is rough on the knees.
Old 02-11-2013, 04:20 PM   #8
syrgrad91's Avatar
Liked 5 Times on 4 Posts
Likes Given: 5
Both of my single-speed conversions are running 42/16, the big difference between the two bikes is that I'm running 27's on the Centurion and 700's on the Peugeot. I haven't measured the crank lengths, so I'm not sure if there is any difference there as well. Not sure what speed I'm doing though, never really paid too much attention to my cadence to calculate it. The gearing seems okay, although I may swap to a larger chainring on the Centurion (maybe a 48T) as I seem to ride that one a bit more aggressively than the Peugeot, and feel like I'm running out of top speed on it.
syrgrad91 is offline
compact crank gearing Botrek Mechanic's Bench 15 10-18-2012 05:25 PM
Question on gearing ... Saugus18 General Bike Discussion 35 02-01-2012 07:33 PM
Racing,gearing, cranks,cassetes rola643 Professional Cycling 3 01-15-2012 02:15 PM
Gearing up for winter rola643 Road Bikes 5 09-23-2011 11:30 AM
Gearing issue question....... Frankie Road Bikes 18 03-01-2011 10:05 AM
