Bike and Cycling Forum > Bike Rack > Fixed & Singlespeed > Single-speed wheel and chain issue
Old 12-18-2012, 02:09 AM   #1
syrgrad91's Avatar
Liked 5 Times on 4 Posts
Likes Given: 5
Hey folks, I'm wrapping up my first single-speed project and I have a question. I took a mid-80's Peugeot Iseran frame and built a pretty nice single-speed out of it. I'm running 700c wheels and swapped out the 8-speed cassette for spacers and a 16T cog. So far so good. The problem is trying to get the rear wheel centered and keep good tension on it and I'm having a dickens of a time. I've seen some bikes with screws drilled into the rear of the dropout that seem to help with alignment and setting proper tension on the rear wheel, however, my bike does not have a provision for that. I've also seen the Surly Tuggnaut, however that's really designed for use with track frames. Any thoughts or suggestions would be helpful. As a point of additional info, I have quick-release skewers on it at the moment and have been debating swapping to a solid rear axle (it's going to stay QR on the front to make it easier to lock up the bike).
syrgrad91 is offline
Old 12-18-2012, 02:35 AM   #2
Residential Noob!
rynoman03's Avatar
Liked 453 Times on 320 Posts
Likes Given: 1160
My friend that built his own SS used a piece of PVC for his spacer and just painted it. It was more functional to him to get things to line up more precise than trying all sorts of spacers. All he had to do is cut, file , sand, and paint.
Also if your no longer using a deraileur you may need to take a spacer out of your drive side's BB if your BB has spacers on each side. This allows the chain to line up a little better.
Just throwing that info out there for ya. I do like the spacer you have though! It's very classy!
Also have you tried a shorter chain or maybe doing a half link shorter?
rynoman03 is offline
Old 12-18-2012, 02:45 AM   #3
Liked 1981 Times on 1308 Posts
Likes Given: 2200
Shop around, and you'll find some chain tugs that will do the trick, even with your dropouts. Switching to a nutted rear axle will help. Search eBay cycling for "tensioner".
Industry_Hack is online now
syrgrad91 Likes This
Old 12-18-2012, 04:40 PM   #4
syrgrad91's Avatar
Likes Given: 5
Nice! I wonder how safe and/or durable that is. Still, I might try that on my next SS bike build.
Yeah, no spacers on the bottom bracket.
Thanks! Just stacked a bunch of aluminum spaces I picked up at a local bike shop. (the first one is anodized black, the rest are unfinished aluminum). They're really nice because they are notched to seat properly on the cassette hub.
The chain lines up perfectly, and the chain length seems to be okay, it's just a matter of getting the rear wheel to sit evenly and taught in the rear dropouts. As long as the wheel is in there straight, then the chain is straight and it all works fine.
Old 12-23-2012, 12:58 AM   #5
still learning
superj's Avatar
Liked 628 Times on 452 Posts
Likes Given: 12
those spacers do look very nice. i thought you bought some kind of special deal to fill in that space, not just stacked up some stuff form the shop, it looks pro
you should try this link:
https://www.biketexas.org/
superj is offline
Old 12-23-2012, 05:47 PM   #6
syrgrad91's Avatar
Likes Given: 5
Thanks! I tried to keep it clean. I thought about buying a spacer kit, but this option was less expensive and looks just as nice. I originally considered using spacers from various old cassettes, but that looked sloppy and didn't fit quite right, so instead I checked with the local bike shop and they had these instead.
Old 12-26-2012, 09:40 AM   #7
retromike3
Liked 8 Times on 6 Posts
think about nuts
One of the best ways to make sure your chain is aligned is to have a solid rear axle with nuts on both ends. Then you can tighten down the non-drive side first. this will allow you better placement for the rearwheel and also gives you a better handle on chain tension.If you do this you don't really need any other hardware. I have in riding fixed gear bikes for years and i've never needed any pullback type adjuster on any of my bikes.
If you go this way. one thing you're going to have to carry with you though. and that'll be a 15 mm wrench or something that'll do the job. I have a medium-sized crescent wrench that I cut the handle off and rounded it and tapped it so that it could fold up and fit in my pocket.
Mike Frye A.K.A. Frye Bikes
retromike3 is offline
Old 12-26-2012, 12:22 PM   #8
Merlincustom's Avatar
Liked 338 Times on 202 Posts
Likes Given: 142
There are a lot of options out there. The best design has an offset head so you won't mar the paint finish.
http://www.google.com/search?q=fixed+gear+15mm+wrench&hl=en&safe=off&cli ent=safari&tbo=d&source=lnms&tbm=isch&sa=X&ei=L_na ULW_E8_y0QHx9IGIDg&ved=0CAYQ_AUoAQ&biw=1024&bih=67 2
Merlincustom is offline
Old 12-27-2012, 07:25 AM   #9
retromike3
if you use a good set of washers you don't have to worry about your paint (mines still OK at the drop outs after twenty years, the frame needs help though) The Idea is you don't need to put that much torque on your rear hub and it will still be there.
Old 12-27-2012, 11:53 AM   #10
Likes Given: 142
I'm talking about the paint at the fork. The rear dropouts are flat. The fork, mine anyway, is shaped such that a flat wrench, fully seated, will nick the paint. YMMV.
first single speed mike215 Fixed & Singlespeed 5 01-18-2013 08:20 PM
My new Single Speed TSage Fixed & Singlespeed 30 10-09-2012 06:04 AM
Chain/derailleur issue harleygold General Bike Discussion 4 07-21-2012 01:50 AM
Hybrid tire or wheel issue? SG-1 Tires / Wheels 6 10-20-2011 09:27 PM
road bike wheel issue Sunlover Tires / Wheels 5 11-06-2009 04:16 AM
