I have (and do) use Mavic and DT rims and have never had any problems with the quality of their products. You should be fine with either brand.
When selecting your rim, spoke count, and lacing pattern, you must consider the riders weight and the type of riding that you will use the wheel for, and type of brakes being used (rim or disc). For a rear wheel, I would not use less than 32 spokes and no less than 28 on the front. Typically, I run 32 double butted front and rear laced 3 cross. For a really strong rear wheel you can even go 36 spokes. There's really no point in using more than 32 on a front wheel. Also, brass nipples are superior to alloy. The small weight penalty is worth it.
A certified wheel builder should know his stuff, but I tend to go on personal references rather than a certification.
I'm not very familiar with this "tubless ready" thing. I did a bit of research on the interweb and it looks like there are some tires being marketed out there to be used with non-UST rims and no sealant.
