Bike and Cycling Forum > General Forums > Tires / Wheels > Presta Valve losing air
Old 10-13-2010, 02:40 PM   #1
funetical's Avatar
Look guys a tech post from me!
Can a presta valve lose air over time? I'm borrowing a friends bike,I couldn't find a leek, but every morning it's flat. I know it wasn't filled to the max when I got it, would that make a difference?
funetical is offline
Old 10-13-2010, 04:26 PM   #2
retromike3
looks like you have a leak
It sounds like you have a slow leak. Usually your tires lose some air over a period of time but the don't go flat. Road bikes that have Presta valves, generally have much thinner tires and tubes and are much more prone to punctures.
You have to keep a much sharper eye out for junk in the road. B.I.T.D. I used to commute with sew-ups and did not get to manny flats, because I could ovoid the bad sections of road.
Mike
retromike3 is online now
Old 10-13-2010, 05:09 PM   #3
funetical's Avatar
It's not my bike, and not the tires I would have chosen, but I need transportation so...
I'm going to be building up my Raleigh soon and am glad I have a little experience with road tires now.
Old 10-14-2010, 01:12 AM   #4
'57 Schwinn Wasp
Gandalfe's Avatar
Did you get a chance to put the tube (with air still in it) and the valve to see where the bubbles are coming from? I mean, that's what I do if there was a leak. Otherwise you're just guessing and so are we.
"Life is like a ten speed bicycle. Most of us have gears we never use." ~ Charles M. Schulz
Blog at: http://biskey7.wordpress.com
Gandalfe is offline
Old 10-14-2010, 04:26 PM   #5
funetical's Avatar
Yeah, there's a leak, I'm going to have to run it down tonight. I can't find it, but I can hear it. I'm going to walk to the LBS later to by a new tube.
Schrader to presta? E-Dog Beginners Forum 10 07-29-2010 02:57 AM
Why are the majority of tubeless tires rigged with Presta Valves? Terri Tires / Wheels 7 04-22-2010 04:53 AM
How do you fill a presta valve? Mike1jw Beginners Forum 6 10-10-2009 09:56 PM
Valve Extenders Etta Road Bikes 1 08-16-2009 12:54 PM
