Bike and Cycling Forum > General Forums > Tires / Wheels > Tire recommendation for durability/size
Old 04-23-2012, 08:03 PM   #1
mars_yeldir's Avatar
Liked 228 Times on 138 Posts
Likes Given: 151
This question has probably been posed before but I thought I would ask anyway. I am having real problems cutting the sidewalls of my tires. I have cut Schwalbe Ultremo ZX, Michelin ProRace3, Specialized Turbo, Mondo, and All Condition. I have had Conti GP 4000 S which I think did a bit better, but I think I cut those too. In fact, it is hard to remember all of the tires I have cut. I ride the same roads as Xela and he gets thousands of miles on tires. If I get 3 months (700 to 1000 miles) that's a long time for me.
I am 6 1 or 2 and weight about 220. I was thinking of going with a 25C tire. An article on Bike Radar said rolling resistance on a 25C is less than 23C anyway. I know of the Continental Gatorskins and some others. I am reluctant to speed 65 bucks a tire unless I am absolutely sure the thing is gonna make it. Any other suggestions? Any thoughts on how much tire weight affects things? 23C v 25C? Thanks for any input.
mars_yeldir is offline
Old 04-24-2012, 01:38 PM   #2
Xela's Avatar
Liked 703 Times on 388 Posts
Likes Given: 646
I was hoping maybe his tire guage was reading low and that maybe he was actually underinflating the tires. But I checked it against mine and that doesn't appear to be the case.
I'm thinking maybe the sidewalls on the tires he has chosen in the past is not stiff enough for a 220 lb rider resulting in more sidewall contact with the road. I do know that the Pro Race 3 pressure chart only shows weights up to 176 lbs and says to run 116 psi for greater than that.
What are some of the bigger roadies around here running?
Xela is offline
Old 04-24-2012, 02:54 PM   #3
kneedrachen's Avatar
Liked 2199 Times on 1344 Posts
Likes Given: 4715
I've close to 220 (just over) and have been experimenting with pressures due to my weight gain from surgery. I'm running Vittoria Zaffiro Pro tires @ 120 psi without incident.
I actually just picked up a set of Michelin 3s, now I'm doubting my purchase! I intend on dropping the weight quickly so it may not be an issue.
I think that if he's routinely breaking sidewalls that it may be a mechanical issue (rim wall deficienies/deformities?) leading to failure or maybe a repeated error in tire mounting or tube size selection/disconnect in sizing?
kneedrachen is offline
Farrowlane Likes This
Old 04-24-2012, 02:55 PM   #4
Likes Given: 4715
Another thought.... Are the brake pads mounted/aligned correctly?
Old 04-24-2012, 05:31 PM   #5
Likes Given: 151
I am running a custom built set of HED wheels that are pretty much the same as the Ardennes. The wider wheels. Brake pads seem to be fine. I really think the problem is that I just hit chunks of gravel, etc. Of course the ideal solution is to not hit that stuff but.......... A local LBS just recommended the Vittoria Rubino Pro Tech. I went to their website and they also make a similar tire, the Zaffiro Pro Tech. Both have extra sidewall protection like the Conti Gatorskins. Thanks for the input.
Old 04-24-2012, 06:21 PM   #6
No longer a newb!
awinter's Avatar
Liked 19 Times on 14 Posts
Likes Given: 3
I'm 6' and when I first started riding, I was over 220 lbs. I was riding with the Specialized Mondo tires at 120 psi and didn't have a problem.
"God does not play dice with the universe; He plays an ineffable game of his own devising, which might be compared, from the perspective of any of the other players, to being involved in an obscure and complex version of poker in a pitch dark room, with blank cards, for infinite stakes, with a dealer who won't tell you the rules, and who smiles all the time." -Terry Pratchett
awinter is offline
Old 04-24-2012, 08:40 PM   #7
skycomag's Avatar
Liked 6 Times on 6 Posts
no one has mentioned how many spokes for 200lb plus riders should have?
i thought it would 32/36 spokes. and what about the spokes gauge 14?
i wgt 195 an my bike,(tire forte mtero k 700x35c), has 36 spoke/14 g spokes and i'm glad it has them.
the bike paths around my area suffers froms lots of speed bump alias tree roots.
hit them at 15+mph has quite a jolt.
Mitch
2011 GT TRAFFIC 4.0
skycomag is offline
Old 04-24-2012, 11:27 PM   #8
Liked 3 Times on 3 Posts
I am a little north of the 220 mark and have no problems running gatorskins 700 x 23 up front with 110 psi and 700 x 25 in the rear with 120 psi.
As for spoke count my rear wheel is a custom DT Swiss RR585 36 spoke count with DT Swiss 14/15/14 spokes. No problems so far with 700 miles on it.
Simon
storksb is offline
Old 04-25-2012, 01:11 AM   #9
Back in the Saddle
Ruffy Tuffy 28s. On a touring rear wheel with 36 spokes. Front is on a 32 spoke pretty standard wheel. Have not had sidewall issues. 215lbs and 3800 miles last year.
Back into cycling after years away from it. Loving it!
Indianapolis IN
2012 Salsa Vaya 3
rawhite1969 is offline
qmsdc15 Likes This
Old 04-25-2012, 12:43 PM   #10
Likes Given: 4715
One last thing about the Zaffiro Pro tires. The sidewall patch/label is actually a separate piece of rubber bonded to the sidewall, rather than just printed. Mine are starting to peel away. At first I thought I had sidewall cracking, but it was just the patch/label peeling away.
GPS recommendation terriann Lights / Electronics 19 03-10-2013 07:29 PM
What Tire Size? EnjoyingtheView Beginners Forum 2 01-20-2012 02:46 AM
Stem Durability and Strength atlantis General Bike Discussion 4 10-24-2011 03:18 AM
Cannondale Q6 tire size? DougY Hybrid 3 04-27-2011 11:17 AM
tire size London Off Topic 2 12-02-2009 03:04 PM
