Bike and Cycling Forum > General Forums > Tires / Wheels > Why are the majority of tubeless tires rigged with Presta Valves?
Old 11-05-2009, 04:18 PM   #1
Terri is offline
Old 12-03-2009, 09:29 PM   #2
I'm glad I did a search because I had the same question. Is it just preference?
Cyclomatic is offline
Old 04-21-2010, 11:14 PM   #3
lots of reasons
One big reason and probably the most technically compelling one is that they are smaller diameter, and if you have a really skinny rim you can't afford a large hole for the valve. In addition the valve head is self cleaning so you don't need a cap and it's tradition. I'm talking road bikes here not Mtn bikes.
All these would come up with a Google search BTW
Martin
85 Merckx 753 Professional
91 Merckx Corsa
00 Serotta CSI
07 PerformanceBike CFR Elite
martinrjensen is offline
Old 04-21-2010, 11:56 PM   #4
Liked 2 Times on 2 Posts
The majority of good wheelsets, tubeless or otherwise, are Presta. Presta is bike specific while Schrader is automotive. Generally, cheap bikes and wheels come with Schrader valves, probably because that's what non-cyclists are used to.
As already mentioned the smaller hole fits smaller rims. It also makes a stronger wheel. Presta is easier to adjust air pressure and with the lock nut installed, filling a flat tire is much easier than Schrader because the stem doesn't get pressed into the wheel when the pump nozzle is pressed down on the stem.
Old 04-22-2010, 12:52 AM   #5
Likes Given: 2
Wow, I would have just said "better design" and left it at that.
Old 04-22-2010, 01:26 AM   #6
Administrator
TxCyclist's Avatar
Better design how? More efficient at air retention?
Unanswered Threads
TxCyclist is offline
Old 04-22-2010, 01:48 AM   #7
Likes Given: 2
As previously mentioned, you need a smaller hole in the rim, as well as nominally lighter, and somewhat easier to use.
Old 04-22-2010, 04:53 AM   #8
The Bearded Wonder
fleeter's Avatar
and easier to bend... don't forget that one!
_ _ ____ __o
----__ _`\<,_
_ ___ (_)/ (_)
fleeter is offline
Tags
Bicycle, Tubeless Tires, Presta Valve, Presta
tires vicg General Bike Discussion 10 05-17-2010 07:51 PM
Help with tires cvgreg Beginners Forum 1 05-05-2010 12:14 AM
How do you fill a presta valve? Mike1jw Beginners Forum 6 10-10-2009 09:56 PM
I think I need to get some new tires hophead Mountain Biking 9 09-18-2009 06:49 PM
MTB Tires: COSMTBFAN Mountain Biking 5 08-29-2009 12:34 AM
