Bike and Cycling Forum > Bike Rack > Beginners Forum > Bike fork clicking
Old 03-03-2010, 03:37 PM   #1
The Bearded Wonder
fleeter's Avatar
Bike fork clicking
Hey guys,
When I'm riding my bike, I notice that my front fork seems to "click" into a straight line with my frame. Now, there's not an audible click, it just seems to tend to slip into a groove or something. Is this normal? or do I have things too tight?
This issue is kinda hard to explain... I'll try again for those that are still lost. My fork has a full range of motion, so nothing worrysome there, but as I turn from a full left to a full right, the fork will pull itself into the straight forward position once it's close to it (within 1*), and then resist leaving that position as I continue to turn it.
Maybe I'm over explaining something that every bike does and I'm just a doofus. Either way, let me know.
fleeter is offline
Old 03-03-2010, 04:58 PM   #2
Liked 2 Times on 2 Posts
Could be an overtightened or bad headset. Could also be a brake or shifter cable that's either too short or wrapped around the headtube. The "click" thing would indicate the former.
Old 03-03-2010, 05:29 PM   #3
The Bearded Wonder
fleeter's Avatar
I think you nailed it... I'll see what loosening my headset does.
fleeter is offline
Old 03-03-2010, 06:47 PM   #4
Likes Given: 2
Loose nut behind the bars...
Old 03-03-2010, 11:56 PM   #5
Younger than Hack
Grape Ape's Avatar
It sounds like the alignment is off just a bit and the power steering pump is not doing it's job. Take it to the dealer and have it all replaced with new parts.
Seriously though. Most of your riding id in a straight line with a small amount oof turning. It sounds as if the the bearings have beat a small dimple into the race. Then as you have ridden and turned it has spread the dimple out to make a ramp into it from either side. As you use it the ramp will wear more and more until it splits a spot in the race and causes real problems. You might want to take it apart and check it to see if it is getting beat up. If nothing else when you clean it up and check it out you will be putting new grease in it and if nothing else you can say you have done some preventive maintenance.
Grape Ape is offline
Old 03-04-2010, 01:06 PM   #6
The Bearded Wonder
fleeter's Avatar
Thanks, guys! Loosened the headset bolt, and it seems a lot more fluid now.
fleeter is offline
Old 03-08-2010, 12:45 PM   #7
DX's Biggest Member
CTD50's Avatar
Double-check your headset bearings anyway; just being a bit looser is a band-aid fix. A new headset with sealed cartridge bearings isn't expensive at all, and will serve you better in the long run.
CTD50 is offline
Tags
fork, wrenching, mechanic, headset, tight
Carbon Fork J_cub Road Bikes 5 10-20-2009 07:09 PM
Fork Mount sabu General Bike Discussion 2 08-17-2009 04:11 AM
Fork Help dixie Mountain Biking 3 08-08-2009 05:18 AM
Lower fork oil powderbock General Bike Discussion 4 07-28-2009 05:06 AM
