For a 1.75 inch wide tire, 50 to 70 psi is a good pressure range for crushed stone and gravel trails. Here is an excellent article from
Sheldon Brown's site on the effect of tire pressure on comfort, handling, and rolling resistance. Especially look at the two tables. One table describes the way to recognize under inflation / correct inflation / and over infllation. The other table suggests inflation pressures for various tire widths and wheel loads. For the purposes of that table, your 1.75 inch tires are roughly 40 mm wide.
Another good article on MTB tire pressure is
this from Bicycle Quarterly
FWIW, my main ride has
26 x 1.75 Continental Travel Contacts with a manufacturer suggested pressure range of 50 to 80 psi. The best tradeoff between comfort and rolling resistance for me on most surfaces is 65 to 70 psi. which is about 5 psi above what Sheldon Brown's table suggests.
